Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 6, 2009, 06:43 PM
KaptCrunch's Avatar
note use ESD safe type soldering iron on MB, for bare wires is ok as long not hooked to any ic's if need to solder MB bring it up to heat then un-plug it from 120v source
the reason is that i've killed a laptop re-soldering cmos battery. after i check earth to tip my multi-meter showed 27vac, i guess element had a voltage leak
dvd trouble part 2 t0m Storage 16 March 11, 2009 05:42 PM
[FS] Partial Part-Out jetOne Buy/Sell & Trade 11 December 27, 2008 12:35 PM
Odd part requirement Exmortis Cases 0 December 3, 2008 08:37 PM
Upgrade Part II Phaddie New Builds 45 November 4, 2008 05:18 PM
OCZ part #OCZ2G8002GK ebdoradz RAM 3 June 3, 2007 06:49 AM
