Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #41 (permalink)
Old December 5, 2010, 06:51 PM
sswilson's Avatar
I'm not sure NVflash will run off of linux, and I know that the great majority of file's I'll want to run off of a bootable stick will be available for dos. Thanks for the suggestion though.
  #42 (permalink)
Old December 5, 2010, 07:55 PM
no worries. i was in a pinch deciding, this one turned out pretty well. its a cool alternative. along with a dedicated dvd with a live cd in it that does nothing but wait for its next use its a great tool to have on the side
  #43 (permalink)
Old December 5, 2010, 08:36 PM
ipaine's Avatar
Originally Posted by _dangtx_ View Post
In line with the above, I have been using the multiboot option from the same page
Boot Multiple ISO from USB (MultiBoot USB) | USB Pen Drive Linux
It is a very handy tool and so far works really good. I currently have a 8GB stick that I can install all versions 32 and 64bit of win 7, Ubuntu 10.10 32bit(I think that is the right version), MemTest+, Offline NT password + reg editor, gparted, DBAN, and a few other things I can't remember right now.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
  #44 (permalink)
Old January 29, 2012, 12:55 AM
taimoorali007's Avatar
I use this software, Its AWSM and easy to install Win7/xp/vista like 1-2-3!
Try this:
Install_RMPrepUSB_Full.exe
Tags
guide
My new OC rig (it's in the making) Dus CPU's and Motherboards 3 August 10, 2007 12:33 PM
Bootable image... omgwtf O/S's, Drivers & General Software 2 June 10, 2007 09:00 AM
AMD making DDR3 support plans Babrbarossa Rumor Mill 4 May 17, 2007 07:22 AM
