Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old December 24, 2008, 05:40 PM
Default Compatibility DDR3/Core i7 920
Hi, Intel have said that core i7 (920 + 940) chips only support DDR3 800/1066 MHz memory but manufacturers have put kits on the market clocked at 1333/1600 MHz? Only the extreme edition of i7 can make use of 1600 MHz DDR3 or higher, which having said also has an unlocked multiplier which puts it at a big advantage for overclocking over its siblings?
My question is, if i were to get a 920 i7, and 1333Mhz triple channel memory, would my cpu make use of as much as it can (1066MHz) and 267MHz go to waste?
Cheers.
Old December 24, 2008, 06:40 PM
This is in the wrong section.. Needs to be moved to cpu and motherboards.
Old December 27, 2008, 02:35 AM
Evylldemon's Avatar
To answer your question anyway... as far as i know, the 800/1066 speeds come from the base clock of 133 with a mutliplier of 6 or 8. If you don't OC your BCLK then those are the speeds that will be used depending on the ram mutliplier setting.
Someone correct me if I'm wrong but that's what makes sense to me. If you have DDR3-1333 then OC your BLCK to 167 to get 3.5Ghz (167*21) and ~1333Mhz (167*8)
Old December 27, 2008, 06:24 PM
lowfat's Avatar
I am pretty sure I can run my mobo @ stock BLCK and still have the ram @ 1333.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
FS: Rampage Extreme, 4GB CSX Diablo DDR3 2000, 4GB OCZ Gold DDR3 1600MHz, E8600 zlojack Buy/Sell & Trade 13 November 15, 2008 04:30 PM
Team Group Introduces DDR3-1800 & DDR3-2000 4GB Memory Kits MAC Press Releases & Tech News 0 September 17, 2008 08:03 PM
FS: OCZ Platinum OCZ3P13332GK 2GB DDR3 2X1GB DDR3-1333 JPxM0Dz Buy/Sell & Trade 2 April 14, 2008 11:40 AM
Ati Crossfire compatibility PaxeSalute Video Cards 7 March 28, 2008 07:07 PM
4 kit ram compatibility issues? AERo RAM 3 December 19, 2007 02:15 PM
