Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old November 19, 2008, 06:32 PM
Default Got any ideas on removing stickers and their left behinds?
hey guys, got any ideas of removing stickers and their left behinds?
and removing any other adhesive goo?
I'm tihnking alcohol, what do you tihnk?
CPU:E8400 @ 3.8GHZ -->Zalman 9700NT HSF
GPU:XFX 5870 1GB
HDD:150GB Raptor,WD500GB,WD1TB BLACK
MOBO:Asus Striker 2 Formula
RAM:OCZ HPC REAPER 4GB 1066mhz pc2-8500 (5-5-5-15)@2.2v
PSU:CORSAIR 750W
CASE:Silvertstone TJ07
SOUND:Auzentech X-Fi Prelude
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old November 19, 2008, 06:35 PM
stickers use blow dryer to heat em up and peel off
residue use wd-40 or goo Gone
Old November 19, 2008, 06:36 PM
3oh6's Avatar
Hardware Canucks Reviewer
yup, Goo Gone is good stuff. acetone works well too but you have to be careful what you are using acetone on, it will eat a few things. plastics in particular i believe.
Old November 19, 2008, 06:39 PM
Supergrover's Avatar
Yeah it "hazes" them
And yes Goo b Gone is awesome stuff.
R.I.P.
Old November 19, 2008, 07:01 PM
sswilson's Avatar
Automotive paint as well. :)
I made the mistake of using nailpolish remover on some "travel stickers" that came with a used car I bought....
Worked wonders getting them off of the windshield, but I was using a cotton ball as an applicator and made the mistake of setting it down on the hood for a couple of seconds... took the paint right down to the metal!!!! :)
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old November 19, 2008, 07:06 PM
"Quote This..."
Windex with ammonia works too.
Old November 19, 2008, 07:08 PM
My dad did that to my moms $500 dining room set.
Old November 19, 2008, 09:04 PM
NyteOwl's Avatar
Careful with WD-40. it contains solvents as well as lubricants.
Obsolescence is just a lack of imagination.
Old November 19, 2008, 09:14 PM
3 of 7's Avatar
I'm betting it's good old kerosene by the smell of it..
I've been using it for years for sticker residue.... It's the wonder chemical.
BTW it also works great for getting tar and crap off my truck.
Old November 19, 2008, 09:43 PM
Sniper's Avatar
for general sticker glue I use Goo Gone works mint on anything & I have never had it eat away paint ect. I used it on my car before to reove stickers & it did just that nothing more.
