The main part of the guide is centered around Molex Fans, which cannot be controlled by programs like speedfan. Although i can add that into the guide as well. thanks EDIT* Can you expand a bit on what you mean, not very electronic savvy. EDIT2* Anyone intersted in buying fans, i think ill make an FS thread pretty soon, i have a box of about 20 sitting in my room. And the only one i use that didnt come with my case is a 40mm on my northbridge |
Sorry for the double post, just testing my signature :D
__________________ | CPU: E6750 @ 4.0Ghz w/TRUE | Mobo: MSI P35 Neo2 FRI | RAM: Patriot 800mhz 4-4-4-12 @ 960Mhz 4-4-4-12 w/OCZ XTC Cooler | GPU: PowerColor HD 4870 w/Xigmatek Battleaxe | HDD: Samsung F1 1TB | PSU: OCZ GameXtream 700W | Case: Silverstone FT01 | |
ariekeh, where do you get the cable? I've looked at crappy tire and bust buy, but no luck. I need to do some wire work on my fans.
__________________ MM H2GO ~ GA-X58-UD5 ~ i7 920 4GB OCZ Gold Edition DDR3-1600GHz ~ ~ Soundblaster Fatal1ty XtremeGamer Pro ~ Samsung SyncMaster 245b 24" 2 WD Raptor 150 GB (RAID0)/ WD Caviar 500 GB ~ Samsung DVD/RW ~ Vista Ultimate 64 |
You can use a pot to control the speed. If you want to get fancy add a capacitor and a transistor. I used to do this when I was building model train speed controllers. I know this is OT but has anyone come across a guide to link two power supplies together ? Might be a solution to use two 500 watt psu's instead of a 1000 watt unit ...
__________________ CPU: Intel E8500, cooler Zalman CNPS 9500 LED Mobo: Asus P5Q Pro Video card: Diamond HD 4870 Memory: Corsair value ram 2 x 2GB DDR2 667 HDD: WD 500GB Sata2 PSU: OCZ GameXstream 600 watt OS: Vista Ultimate 64bit |
| Quote:
I got most of the cables from odds and ends, and some of them came with fans i already had. or i switched around the cables of the actual fan
| Quote:
only place i could find it easily
__________________ Intel Core 2 Duo e8400 @ 3.8GHz 2GB OCZ Platinum @800 MHz Asus P5N-D BFG Geforce 8800GT OC WD 500GB NZXT Apollo OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F |
I'll need to dig through my notes and post back, may take a few days ...
| Quote:
*Edit I am no electrical engineer but this one looked promising: Sharing the Load between PSU's in a system By: Yo-Duh_87 Sharing the Load between PSU's in a system By: Yo-Duh_87 (page 2, Going further)
__________________ Phenom x4 9950 BE, Gigabyte MA790GP-DS4H, 2x2GB G.SKILL F2-8000CL5D-4GBPQ 250GB 7200.10/640GB&500GB 7200.11 'Cuda, Samsung SH-S203N/Pioneer DVR-112D Radeon HD 3850 256MB, 22" Acer X223W Corsair TX750W, Generic(?) ATX fulltower case (6x 5.25"/9x 3.5") Sansui G-4700 receiver +2x 60w spks/Yamaha YST-M7 Last edited by MacJunky; November 19, 2008 at 05:20 PM. |
OK found it We need 1000 MF capacitor,voltage regulator and 1K pot. I'm sure a 5K pot would work and for the other parts just get something that can handle the voltage like 0 - 16v. Then you need to look up how the B, C, E are configured on the particular component you are using. Like on the voltage reg TIP 29C they are in the order shown. you may need to look it up and confirm the position. Set up using a battery or something before you wire into the computer psu and test using a voltage meter or a fan.
| Thread Tools | |
| Display Modes | |
