Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old September 15, 2008, 06:29 AM
Dr_BenD_over's Avatar
Default Dr. B's TtMFR
AKA the circuit I use to change the front panel lighting on my case. Not really a guide, just the basic schematic and the parts list.
TtMFR Parts List
Nichia NSTM515AS Full Colour LED, Common Anode
3pcs 500R Potentiometer, Carbon, Linear (Digikey # CT2201-ND)
2pcs 150R Resistor
1pc 68R Resistor
3pcs SPST of SPDT Toggle switches (Digikey # CKN1066-ND)
Misc connectors for power and if you want to remove it easily.
3pcs Knob, Clr. Matte, .5” Dia. .125” Shaft (Digikey # 226-3010-ND)
Proto Board
¼” Lexan or Plastic for backing material
5.25 or 3.5 cover plate from your case.
These pics show an addtional 3 channel fan controller as well as connectors for internal case lighting.
The LED's were about $20US each when I first got them several years ago, but there should be much cheaper full colour diodes available now. The fixed resistors values may have to be tweaked to use a different LED. I use 4 LED's to light up my front panel, and they're wired in paralell.
Old September 15, 2008, 06:42 AM
Sweet! Takes me back to first year Circuitry in Uni!
Old September 15, 2008, 07:49 AM
Jack Rabbit's Avatar
Great! Thank you again!
Are the regulators part of the fan control then?
- James Graham
Old September 15, 2008, 07:53 AM
Yes. It's like this:
Only 3 channel.
Old September 15, 2008, 09:27 AM
i don't see any pics
Old September 15, 2008, 09:34 AM
3.0charlie's Avatar
I do; pics and diagrams.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old September 15, 2008, 04:07 PM
bojangles's Avatar
Wow I have never seen such a simple circuit in a long time lol. Ugh I wish university was this easy again. I think I may just build something like this!
Old September 15, 2008, 07:59 PM
Lima's Avatar
I wish I could understand the diagram. Anyhow, really nice!
Old September 15, 2008, 08:21 PM
Menello's Avatar
Nice diagrams!
The box:
Mobo: eVGA NF66 nForce 650i Ultra SPP
CPU: Intel Core 2 Quad Q6600 @ 3.03GHz
RAM: 1x2GB
OCZ DDR2-800 PC2-6400
+ 2x2GB Crucial DDR2-800 PC2-6400
= 6GB RAM (finally more than 2GB!)
GPU: XFX GeForce9800GTX+
HDDs: 500 Seagate, 640 GB WD Caviar Black
PSU: CoolerMaster 600W
Old September 16, 2008, 09:13 AM
BrainEater's Avatar
Nice work !
I actually run RGB lighting in my case as well...Although I'm running individual LED's rather than RGB ones.....
The 6 wire RGB led's are about 6$ now.
At the moment I've just got mine setup for 'color switchable' (no dimming).
I am deperately waiting for Matrix Orbital to build the controller cards for the GX typhoon.Once I get one , the led's will be software controlled PWM.....
edit :
Here's a pic ;
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Crucial m4's/WD raptors/etc...
