LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old September 4, 2008, 06:58 PM
Urotsukidoji's Avatar
Level up: 77% Level up: 77% Level up: 77%
Level: 7 - 33 points to level up
Default BEST 30" high end LCD Monitor?????
OK, I've been looking at the Samsung 305T 30IN Widescreen LCD Monitor 2560X1600
that was reviewed here, and it sounds pretty cool. However, I know Dell (
Dell 3007WFP) and HP (HP LP3065) have some good modles. I want this for gaming, gaming, gaming, and reg PC usage. I do not watch movies on my PC. So, what is the best? Would want to keep it under $1500...
MOBO - ASUS P5Q Pro
CPU - Intel Core 2 Duo E8400
GPU - Visiontek Radeon HD 4870 (x2 in Crossfire)
RAM - Mushkin HP2 6400 4GB (2x2GB) DDR2
HDD - Western Digital Caviar 640GB SATAII (x3)
MONITOR - ViewSonic G220fb CRT
PSU - PC Power & Cooling Silencer 750 Quad Crossfire 750W
CASE - Antec Nine Hundred Black Steel ATX Ultimate Gamer Case
HEATSINK -Xigmatek HDT S1283
SOUND CARD - Asus Xonar DX 7.1
OS - Windows Vista Home Premium 64BIT
Old September 4, 2008, 07:51 PM
lowfat's Avatar
Level up: 65% Level up: 65% Level up: 65%
Level: 14 - 205 points to level up
If all you do is game, then either of those displays are fine. Both the 305T and the 3007WFP use the same panel AFAIK.
Old September 4, 2008, 10:48 PM
Thund3rball's Avatar
Level up: 55% Level up: 55% Level up: 55%
Level: 14 - 263 points to level up
Hmm as far as I know the Samsung 305T has a Samsung S-PVA panel. The Dell 3007WFP uses an an S-IPS LG panel. For gaming you're probably better off with the Samsung as it'll be a lower response time, howver the Dell will have superior colour reproduction.
I game on my Dell 2007WFP S-IPS panel with a 16ms response time. The 3007 has 14ms I believe. I don't ever get ghosting but I do get screen tearing on very high settings on some games. I would use vsync if I'm lazy to take care of it or triple buffering if I want to get fancy... either works.
Desktop
AMD 5000+ BE @ 3.2GHz \\
Tuniq Tower 120 \\ Gigabyte GA-MA770-DS3 \\ Mushkin 2x1GB HP2-6400 \\ Corsair HX520 \\ Evga 8800GT SC w\Zalman VF900 \\ Seagate 3x250 7.2K \\ Dell 2007WFP \\ Razer Deathadder \\ XP
Laptop
Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ Vista Ult. (RED)
Old September 5, 2008, 07:41 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
From experience, the Gateway XHD3000H is THE BEST 30" on the market...bar none. My buddy bought one from NCIX and let me tell you, it is stunning and has more features than you could ever want.
Canadian Prices: Gateway - Gateway 30" Widescreen HD LCD Monitor (XHD3000H) - XHD3000H
Looks like Compu2000 (another NCIX company) has it will free shipping!!!!!
Old September 5, 2008, 09:21 AM
lowfat's Avatar
But he doesn't need a scaler, multiple inputs, PIP. Plus for just gaming, it is not near as good as the 3007WFP and the 305T because of the scaler causing input lag.
Great monitor yes, but if you were use it only as a monitor, there are definitely other ones I would buy first.
Old September 5, 2008, 09:32 AM
SKYMTL's Avatar
Funny, I didn't notice any input lag and my friend is one of the top ranked CoD4 players so I am surprised he hasn't complained...
Old September 5, 2008, 10:03 AM
Does your buddy get the "black out" and input lag issues mentioned in this massive thread?
Gateway XHD3000 - 30" Widescreen Extreme HD Display - Page 38 - [H]ard|Forum
MOBO - ASUS P5Q Pro
Old September 5, 2008, 10:13 AM
SKYMTL's Avatar
According to him he hasn't experience either yet. But looking at that thread it does seem to me that the quality of the monitor is a bit suspect.
Old September 5, 2008, 10:18 AM
Level up: 22% Level up: 22% Level up: 22%
Level: 15 - 508 points to level up
Read that thread. When you run at the native resolution you get no input lag. Or simply, don't use the built in scalar. You need to twiddle with the advanced timings in your vid card to get rid of the blackout issue, improper timing pulses.
Old September 5, 2008, 10:23 AM
SKYMTL's Avatar
Why would someone buy this monitor and not use native resolution? I mean I understand what the Scaler is used for running something like an Xbox 360 or PS3 but buying a monitor like this, running it at non-native resolution and then complaining there is input lag is just...well....what I want to say isn't fit for the forums.
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/display-units/9857-best-30-high-end-lcd-monitor.html
Posted By For Type Date
Sympatico / MSN Shopping This thread Refback November 24, 2008 08:39 AM
