Old August 31, 2008, 08:26 PM
mattlef's Avatar
Level up: 33% Level up: 33% Level up: 33%
Level: 12 - 272 points to level up
Default LCD TV as a Monitor?
I'm looking at this 32'' TV as a computer monitor, and wondering if those who use 30+ monitors can chime in, as to what they think of these TV's as monitors...
Future Shop: TV & Video: 30"-39" TVs: Insignia 32" Flat-Panel LCD HDTV** (NS-LCD32-09CA)
I chose this monitor because it looks equal to all the other pannels I've looked at, including the Aquos, and represents over 100 in savings.
Is Native Res really 1366 x 768 for these or is that just the 720p res?
My Rig:
E8400 4.0GHZ (3.0ghz) | Asus P5Q-E | Xigmatek HDT-S1283 HSF | EVGA GTX 280 | 2x Mushkin Ascent PC2-8000 Dual Channel 4Gb
2x 320gb WD HDD 7200rpm - 1x 160gb WD HDD 7200RPM | Coolermaster 650W PSU | Silverstone FT01 CSE | Samsung SyncMaster 216bw
My Silverstone Fortress Mod
Upcoming Changes/Upgrades:
Heatware: mattlef
Positive: 3 Negative: 0 Neutral: 0
Click Here Click Here For Ebay
Old August 31, 2008, 09:00 PM
Level up: 14% Level up: 14% Level up: 14%
Level: 17 - 687 points to level up
1366x768 is the res.
My brother has a 26" LG as his monitor with the same res. Looks fine but things are "big" due to the low res. I tried running 1080i on it and it runs but everything is impossible to read.
I'd personally just get a 24" LCD monitor with a 1920x1200 res.
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old August 31, 2008, 09:23 PM
yamawho's Avatar
Level up: 53% Level up: 53% Level up: 53%
Level: 11 - 161 points to level up
I have my HTPC hooked up via the HDMI for sound and video to a Samsung LN40A530 40" LCD LN40A530 LCD TV - TV SAMSUNG
According to the research I did, 1920 x 1080p is not really noticeable over 1920 x 1080i for TV's under 55" unless you hook it up to a PC and read text. Then p or progressive is recommended.
Text, movies whatever are very clear
This TV is setup to accept the input signal from a PC on HDMI 2.
According to the manual it will do the following with HDMI/DVI input:
VESA
640 x 480
800 x 600
1024 x 768
1280 x 1024
1360 x 768
1600 x 1200
CEA 1920 x 1080P
"If the signal from the system equals the standard signal mode, the screen is adjusted automatically. If the signal from the system doesn’t equal the standard signal mode, adjust the mode by referring to your videocard user guide; otherwise there may be no video. For the display modes listed below, the screen image has been optimized during manufacturing."
CPU: Intel E8500, cooler Zalman CNPS 9500 LED
Mobo: Asus P5Q Pro
Video card: Diamond HD 4870
Memory: Corsair value ram 2 x 2GB DDR2 667
HDD: WD 500GB Sata2
PSU: OCZ GameXstream 600 watt
OS: Vista Ultimate 64bit
Old September 1, 2008, 12:26 AM
Dashock's Avatar
Level up: 2% Level up: 2% Level up: 2%
Level: 17 - 785 points to level up
Get the Sharp Aquios or the Samsung 32inch asss long as they support 1080p Captain Vortex loves his Sharp ask him and i love my Samsung only thing missing in my is the 1080p i wonder if i can replace it with the new model since i got the 4 year warranty?
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old September 1, 2008, 09:30 AM
mattlef's Avatar
I've been looking around at the 1080p Aquos,
Those who have it.... how are your experiences? do you get ghosting when gaming?
Would I really, need to upgrade my video card to play most games stable at native?
If so, 4870 or 2x4850's or GTX260?
My Rig:
Heatware: mattlef
Old September 1, 2008, 10:07 AM
lowfat's Avatar
Level up: 65% Level up: 65% Level up: 65%
Level: 14 - 205 points to level up
I love my Aquos 32" 1080P. I would never go back to a smaller monitor again. Text is easy to read, games are amazing to play because of the size. I am sure your 9800GTX should be sufficient for most games.
Old September 1, 2008, 05:39 PM
mattlef's Avatar
I dont know if it will... I'm a huge fan of Crysis and I dont know if it will play well at native 1080 using this card...
I'm almost 100% sure I'm going to get the Aquos 32'', but the Insignia 32'' would be good, at 300Cheaper (although 720p)
Would there be that big of a difference between 1080 and 720 when gaming?
My Rig:
Heatware: mattlef
Old September 1, 2008, 05:49 PM
Gaming would be alright at 720p IMO though anything else would suck since the resolution is just too low for such a large screen. You'd loose quite a bit of productivity having such limited screen space.
4-4-4-12-2T
X-Fi XtremeMusic
Antec 900
[ HEATWARE ]
Old September 1, 2008, 06:22 PM
mattlef's Avatar
So, 1080 would prolly be the bet.... hmm, so much for trying to save an extra couple hundred dollars lol
My Rig:
Heatware: mattlef
Old September 1, 2008, 07:16 PM
lowfat's Avatar
Sitting 2 feet from the screen you definitely need 1080P if you are using it as a main display. I was going to say besides Crysis about the 9800GTX.
