Old August 17, 2008, 10:41 PM
Trial Member
Default 24 inch gaming lcd
Heya, wondering what you think is the best 24 inch monitor purely for gaming purposes.
Also what do you think of the Samsung SyncMaster 2443BW, there seems to be no reviews of this monitor anywhere on the net, it's on special at ncix for 379$.
Thanks.
Old August 17, 2008, 11:26 PM
Not particularly impressed w/ the 22" version ... The 24" may be different, but I doubt it would be much, if any, better ...
Old August 17, 2008, 11:30 PM
IMO LCDs have a long way to go - most of the LCDs in this price range don't use the best panels and are biased towards blue - and the ratings are usually inflated or overrated - I'm honestly waiting for OLED, I can't stand LCD's input lag - some people are happy with gaming and some low end monitors - but if you want something really decent I recommend an $18,000 24' OLED ;)
BTW, that specific model of Samsung you are looking for, saw it on display, wasn't impressed with color or viewing angles - That monitor uses a TN panel.
Old August 18, 2008, 12:10 AM
Jon_di2's Avatar
Thanks.
Not that great of a price for that monitor... I wouldn't think of that to be special in any way, pricematch it and I'm sure you can get it down to around 150
Probably should have just posted in the thread below yours too... I recommended this one: BenQ V2400W 24IN Widescreen Black LCD Monitor 2MS 1920X1200 4000:1 Senseye HDMI DVI VGA
$400 with shipping included... so it will probably cost you the same as the Samsung Syncmaster
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old August 18, 2008, 11:30 AM
What panel does the BenQ use ?
Old August 18, 2008, 11:49 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Best bet is to go to a shop and compared some you like side by side. I like this one personally.
NCIX.com - Buy BenQ G2400WD 24IN Widescreen Black LCD Monitor 2MS 1920X1200 4000:1 Senseye HDMI DVI VGA - G2400WD In Canada.
