Old August 1, 2008, 02:08 PM
bump.
Old September 4, 2008, 11:50 AM
Wow no replies? I bought my 2053BW in May for $220+tx. Anyway both units have the exact same specs even the same native resolution, wonder if power consumption is the same?
Old January 15, 2009, 09:58 AM
anyone?
Old January 15, 2009, 10:00 AM
sswilson's Avatar
I'm running the same monitor, but the only setup I did was the Samsung standard of dropping the brightness down from 100% to about 40. :)
Old January 15, 2009, 05:20 PM
Nodscene's Avatar
I pretty much stick with the controls on the monitor itself, that way no matter how many times I format or do whatever it will pretty much always be how I like it. I found this site (LCD monitor test images) to be invaluable and about the best one I've seen so far.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old January 15, 2009, 06:42 PM
I'd like to hear some people on this. I just picked one up a few weeks ago, Friend of mine was telling be about "setting it up" which I will be doing on the 31st when I see him at a LAN. Any updates in the mean time would help.
Old January 15, 2009, 07:23 PM
Jake_HT's Avatar
I have a 226BW.. I assume it's similar?
22" 1680x1050
2ms
3000:1 CR
60Hz
My settings:
Brightness: 100
Contrast: 80
Magic Color: Intelligent
Color Tone: Normal
Color Control: 50, 50 ,50
Gamma: Mode 1
Coarse: 1840
Fine: 0
Sharpness: 72
Old January 15, 2009, 07:53 PM
Will try that tonight. thanks!
Old January 15, 2009, 08:17 PM
I have the same monitor. I installed it with the Catalyst Drivers for Vista 64-Bit. You really don't need any special setup for normal use. However if your games need it, or in my case if you are doing photo editing yes. I have Pantone's Huey - its easy to use and not very expensive. It will check your ambient room light and calibrate your monitor with its supplied Sensor.
ASUS P6X58D-E; INTEL i7 950 ; NOCTUA NH-U12P; PNYGeForce GTX 460 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 8 PRO 64-BIT.
