  #31 (permalink)
Old July 20, 2008, 12:59 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
All right, to follow up I did a bit of running back and forth today to check out some of the claims made in this thread.
I ran over to my parents' place, picked up their Pioneer BDP-95FD, ran it back to my place, plugged in my trusty Hiper HDMI to DVI-D adaptor, plugged it into the 305T and loaded up Top Gun (GREAT 1080P Blu-Ray movie).
Guess what? No picture. All I get is the No Signal rotation through the primary colors which is the norm when there isn't a cable plugged into the monitor.
I used a standard Samsung DVD player with Lord of The Rings, the same HDMI to DVI connector and it worked on the 305T...but looked like crap.
I plugged the same getup into my Westinghouse LVM-42W2 through the DVI-D port and guess what? No poblemo!!! Looks beautiful and plays without a hitch.
You all can say what you want but after the time I spent looking into this today while worrying I did something wrong in the review, I now consider this matter closed. Now to return my parents' Blu-Ray player...
  #32 (permalink)
Old July 20, 2008, 01:01 PM
Level up: 86% Level up: 86% Level up: 86%
Level: 9 - 34 points to level up
You need to get a Dell in (3008WFP or 3007WFP-HC) for review, or the Gateway with the awesome [though some input-lag inducing] scaler.
Then you'll want to get rid of the 305T
Main:
Asus P5Q Deluxe | Q9550 @ 3.95 GHz | TRUE + 2x Noctua NF-P12
4x2 GB Mushkin 996580 @ DDR2-930 5-5-5-15 | BFG GTX 280 OC
150 GB Raptor; 4x 1 TB (2x Seagate; Samsung, WD); 500 GB Seagate
BenQ DW1640 | Corsair HX1000 | Dell 3007WFP & Samsung 204T | Vista Ultimate x64
Secondary:
Asus P5B Deluxe | Celeron E1200 | TR Ultima 90 + Noctua NF-P12
2x2 GB G.Skill PQ | HIS X1300 512MB
6x 500 GB (2x WD, 2x Maxtor, Hitachi, Seagate)
NEC ND-3550A | Corsair HX520 | Samsung 204B | Vista Ultimate x64
  #33 (permalink)
Old July 20, 2008, 02:02 PM
SKYMTL's Avatar
The 305T has its uses. I find it great for gaming and Photoshop work since the color reporduction is spot-on.
Unfortunately, my Pioneer HDTV is down for the count and I am still waiting for a replacement since the Westinghouse needs to go back when my buddy gets back from Europe next week. Looks like I will be looking for a new HDTV pretty soon. Ugh.
  #34 (permalink)
Old July 20, 2008, 02:12 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Thanks for testing.
Hockey Mod at your service
  #35 (permalink)
Old July 20, 2008, 10:27 PM
Chilly's Avatar
Level up: 15% Level up: 15% Level up: 15%
Level: 12 - 344 points to level up
NIp-pick all you want, but for the life of me I couldn't get the monitor to raise up or down. I actaully have the stnad right in front of me and there is ZERO height adjustment.
Actually, I think I see the problem, the monitor Samsung sent me was the LS30HUBCB/XAA. However, the specifications they have up on their site and the specs they sent me were for the LS30HUXCB/XAA. Seems that there were a few things changed but I will contact my Samsung rep to see what they were. However, at the time of reviewing I had a conversation with Samsung and they confirmed the monitor I had did not have height adjustment.
No Issue, perhaps this revison, there is no adjustment, again I was just relaying what I had seen in other reviews
Also, I checked out my HTPC hooked up to my BenQ FP231W, and it seems your correct, thou for some reason I DO remember being able to play HD Movies on this moniter at somepoint. On this point I concede that I was incorrect :). Again thanks for testing and double checking out some of this info . Guess this means I'm still looking for a moniter for my client
  #36 (permalink)
Old July 21, 2008, 12:43 PM
Level up: 95% Level up: 95% Level up: 95%
Level: 3 - 2 points to level up
True but like it has been said already: this monitor DOES NOT support HDCP which was the entire starting point of this conversation.
I agree, I just wanted you to fix the error in the review. Remove the "thus" and I'd be happy.
  #37 (permalink)
Old July 21, 2008, 12:44 PM
Who would ever hook up a standalone player too? Don't you own a TV? lol.
Desktop: Intel Q6600, ASUS P5B, 4GB Mushkin, EVGA 8800 GTS, 750W Silverstone Strider, 23" Apple Cinema Display
HTPC: Intel E6600, ASUS P5K, 2GB Mushkin, EVGA 9600 GT KO, LG HD DVD/Blu-Ray Combo, 600W Silverstone Strider, 46" Sharp 1080p LCD
Server: AMD X2 4400+, ASUS A8N32-SLI, 1.5GB Corsair PC-3200, 1x1TB, 1x750GB, 4x500GB, 1x320GB Seagate, 625W Enermax Modu82+, Coolermaster Stacker Evo
  #38 (permalink)
Old July 21, 2008, 01:02 PM
Eldonko's Avatar
Anyone that doesnt have a HDTV bigger than 30 inches would. Which is a lot of people, me included.
  #39 (permalink)
Old July 21, 2008, 04:55 PM
That sucks.
  #40 (permalink)
Old July 21, 2008, 06:25 PM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
Me too, I'm still sitting with a 36" CRT TV a Toshiba that weights a ton. (on a plus side I'd like to see someone try and steal it LOL) I want to get a least a 37" HDTV for my basement. As for my monitor it's a 20" Widescreen LG LCD.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
