Old May 14, 2018, 09:24 AM
Mr. Friendly's Avatar
Default wall mount for 2x U3415W's?
looking to mount my two U3415W's in stacked orientation on the wall...but rather than use two wall mounts, I'm looking for something that can do two.
anyone know of something that can do this?
Old May 14, 2018, 09:45 AM
Lysrin's Avatar
I didn't have any luck. Someone might come up with something but I think that is a pretty tall order. I was looking for options a while back myself. Ended up going with a tall desk mount option for my top monitor to put it above my 34" that also has it's own desk mount. My top one is only 21.5" but the one I bought would support bigger. It can get a bit wobbly though if your desk isn't sturdy.
I think your best option, depending on your setup and requirements and if you need wall mount, might be two separate arm wall mounts, mounted one above the other. Might give you the greatest flexibility.
... and this is where someone would swoop in with exactly what you need ;) as I am typing this.
i7 4790K @ 4.5GHz (Swiftech H240-X) | ASUS Z97-Pro WiFi | 32GB Patriot Viper 1600MHz | ASUS ROG GTX 1080 Ti Strix | EX920 512GB, MX100 512GB, MX300 2TB, HDD 500GB (x2) | EVGA Supernova 850W G2 | Corsair 650D | Mayflower Electronics O2+ODAC, USB sound for mic, Sennheiser PC360 SE | Acer Predator X34, BenQ 21.5" | Windows 10 Pro
Old May 14, 2018, 12:43 PM
I bought a dual arm unit off of Monoprice that was reported to support having two 3415w stacked....but I realize now that will be flush with my desktop and i can't have my speakers or anything under it.
I might be able to use a riser, but that gets messy and complicated. :(
Old May 14, 2018, 03:35 PM
KaptCrunch's Avatar
simple add 1 or 2 lack shelve for speakers
Old May 14, 2018, 09:34 PM
The Great Gazoo's Avatar
I built a riser that my 34" LG ultrawide rest upon and then a corner wall mount for my 43" 4K TV right above it. Works out pretty good.
Old May 15, 2018, 06:39 AM
Sagath's Avatar
That better be a rye and ginger and not scotch with ice in it, you heathen
Old May 15, 2018, 07:12 AM
that's right Gazoo, it should be scotch & coke!
Old May 15, 2018, 07:14 AM
that said, I was hoping to invert my second display so the thin top bezel is below and matches the thin bezel for the lower screen.
that said, where my equipment is going used to be a small closet, so there's not much space to play. I might just have to find those B&O wall mounts for my S8 speakers.
Old May 15, 2018, 07:42 AM
Caldezar's Avatar
That's what bourbon is for...
Old May 15, 2018, 09:14 PM
100% Wiser's Deluxe on the rocks. I never mix my whisky.
Wall mount TV Alpine Display Units 9 December 29, 2014 02:28 PM
Microwave wall mount or bracket kit Arinoth Off Topic 6 September 29, 2014 10:36 AM
Yamakasi CatLeap Q270 Stand and Wall mount mattlef Price Check 4 September 7, 2012 06:55 AM
Wall mount advice Kilauea Display Units 5 January 12, 2012 07:35 PM
top mount- bottom mount - does it make a difference? johnnyblazzwa Power Supplies 5 December 20, 2009 09:13 PM
