Old post, but beware the Viewsonic LCDs. They advertise 1080p but it's NOT achieveable via computer. It's locked to 1680x1050 or below. Same deal with the n4785p. There is a Viewsonic model that supports 1080p via Computer, but I don't have the part number off hand. It's listed on the website. EDIT: The 1080p via comptuter is n4X90p replacing X with 2 or 7. Last edited by death_hawk; July 3, 2008 at 06:18 PM. |
If you plan on going 27" or larger, the screen needs to be 1080p, and those start at 32". Westinghouse makes 37" and 42" computer monitors (LVM-37W3, LVM-37W3se, LVM-42W2). Really, they're TVs, but they're considered monitors because they lack built-in tuners. They're quite good as monitors if you ask me. Anything beyond 42" is really too large as a monitor. The pixel pitch becomes too great. However, when you're spending that much, you might as well get a Dell 2707WFP or 3007WFP-HC. The 2707 is probably a better choice, as it has a 1920x1200 resolution; 3007 is a whopping 2560x1600. You can snag a 2707WFP for a couple hundred less than a 32" or 37" 1080p LCD, and it'll have considerably better colors and contrast. |
Hmmm....my Aquos 32" 1080p doesnt have VGA.... nor DVI. Only HDMI's. But DVI-HDMI cables do the full 1920x1080 no problem
__________________ The Vortex H20 Case....not sure what to call it DFI X38 LT Xeon X3210 @ 3.2GHZ 1.30V PNY 9800GX2 (750/2200) 4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V Ultra X3 1000W PSU HT Omega Striker 2x500GB Hitachi RAID 0, 250 Seagate Sharp 32" Aquos 1080p Benq W500 1080i Pojector. Watercooling: Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro. Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res. |
| Thread Tools | |
| Display Modes | |
