Old May 25, 2008, 11:35 PM
Default Monitor randomly going blank screen
I got this 19" ProView monitor that is acting really strange.
It won't stay on for more than a few minutes at a time. Generally the screen will flicker briefly and then the monitor will just go black. Although it doesn't always flicker before it goes blank.
If I press the power button off and turn it back on, it'll stay on for a few minutes again and then just go blank.
Dieing monitor, a way to fix? Anything.
Mobo: MSI i875P MS-6758
CPU: P4 Northwood
RAM: 2x512mb Kingston
GPU: 6600GT 128MB AGP
Monitor: Gem GM-170B 17"
Old May 26, 2008, 01:18 AM
you've had this monitor for a long time? you could try changing the vga/dvi cable i've had that happen a couple times in the past and changing the cable always worked for me.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old May 26, 2008, 04:51 AM
Jack Rabbit's Avatar
Percussive maintenance?
- James Graham
Old May 26, 2008, 02:59 PM
Talking
If its a crt monitor? and cabling is fine...try another monitor.
No trouble with the swapped monitor?
toss your old proview out.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
