Old September 4, 2016, 07:07 AM
Default Monitor Ultra-wide 34 No G-Sync or Wide 27 with G-Sync
Hello,
I am stuck, which Monitor to choose.
An Ultra-Wide Monitor 34, 3440 x 1440, Without G-Sync.
Or
A Wide Monitor 27, 2560 x 1440, With G-Sync.
The deal here is if G-sync worth to scarify the huge large size of 34, 3440 x 1440 or No it is not?!?!?
My Build List : https://pcpartpicker.com/user/Dolomats/saved/
***NB: Please justify your choice :p***
I will give you two example of Monitors who illustrate this:
Ultra-wide : https://pcpartpicker.com/product/yhM...monitor-u3415w
Wide : https://pcpartpicker.com/product/ttn...-xb271hubmiprz
Thanks you.
Old September 4, 2016, 09:23 AM
JD JD is offline
Just so you know, LG announced a 34" 144Hz last week. Not sure if it will be G-SYNC or not, but that means the panel will exist and I'd imagine Acer or ASUS would add the G-SYNC module.
Acer and ASUS already have G-SYNC 34's, but they're only 100Hz (overclocked 60Hz panels as far as I know) and cost about $600 over a non-G-SYNC model.
I personally love my U3415w, so I'm obviously biased
Old September 4, 2016, 09:29 AM
lowfat's Avatar
Unless you can drive your refresh rate 100% of the time, an active refresh rate tech (gsync/freesync) is required IMO. The smoothness it provides helps a lot w/ immersion. Without a doubt i'd go w/ the 27".
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 4, 2016, 01:05 PM
FreeKnight's Avatar
This is probably one of the most important factors. Keep in mind how high you want your eye candy settings and what GPU you're pushing. If you're on a 970 and really like high/ultra settings, you're not going to maintain 60fps let alone 100+ on a lot of games so the 144HZ is a bit of a waste.
If you want silky smooth twitch shooters and can live with the settings turned down to maintain a frame rate, then sure 100+ hz will look really smooth. I guess it depends on what your priorities are and what games you tend to play. In most genres outside of games like COD, Unreal, etc, the cost vs return of a high refresh monitor isn't worth it IMO (and I had a 120hz monitor in the past). I'd lean for Gsync myself.
Old September 4, 2016, 01:23 PM
So you have this monitor! Are you gaming on it? How it perform? Do you notice the low refresh rate what is the cons and pros?
Thanks.
I have GTX 1080, I am playing most of time GTA, and I certainly want the game to be smooth as much as possible.
Old September 4, 2016, 02:39 PM
lowfat's Avatar
IMHO once you get use to a high refresh rate it is hard to go back. Anything under 90FPS looks rather terrible to me these days. A GTX1080 should be able to drive most games @ 2560x1400 w/ high detail and high refresh rate.
Queen of Dreams WIP
Big Lian Li
Complete
Old September 4, 2016, 03:59 PM
If you really want a 34" you can get the ones with Gsync unless you want to save a bit of money cause they're still expensive. Also just an fyi for the Acer 27" you want, it has a flimsy stand, so make sure you have a very solid desk or a monitor mount or its going to shake a lot. Check out video reviews on youtube.
Old September 4, 2016, 04:25 PM
JD JD is offline
Generally speaking, everything I play runs at least 60FPS on my 980 Ti, so no complaints with gaming. I've never owned G-SYNC though so I can't make that comparison. The best I can say is that I have used the Acer X34 Preadator in-store and it did seem smoother, but it was also a game I've never played.
I love the increased FOV though and thankfully pretty much every recent game I've played, other than Overwatch (or any Blizzard game), supports 21:9.
I don't see myself ever going back to 16:9/10 monitors though. I'll definitely consider upgrading to the "next gen" of ultrawides though.
And for reference, this is the new LG that's coming: LG 34UC79G-B | LG Electronics DE (only seems to be on the German and Chinese site). Just noticed it's only 2560x1080 though
Old September 5, 2016, 09:56 AM
Thanks guy's for you precious opinion
Old September 5, 2016, 11:02 AM
FreeKnight's Avatar
Technical Data says native is 3440
Native Auflösung 3440 x 1440
I love my 34" LG, but I'm definitely going to keep my eye out for a Gsync LG 21:9 or see if the ASUS one ever hits a decent sale.
Tags
gsync , monitors , utrawide
Acer announces a 4k monitor with G-Sync! belgolas Display Units 15 October 17, 2014 01:05 PM
Samsung 2253BW 22" Wide LCD Monitor-BLK Mr. Gruntsworthy Display Units 4 October 21, 2008 07:21 AM
Looking to buy my first 22" wide screen monitor Canadianguy Display Units 37 November 19, 2007 06:56 PM
