Old April 14, 2014, 08:17 PM
TTC TTC is offline
I'm selling my 3 24" gaming monitors for the new Asus rog :D
Old April 14, 2014, 08:52 PM
Wow. Must be something then. :)
Frugalmeister
Old April 14, 2014, 09:05 PM
SugarJ's Avatar
Originally Posted by Frugalmeister View Post
Hmm, yesterday's reply never went through.
Thanks for your suggestions and advice JD and everyone else.
Using the computer at a distance wouldn't work for me---I need to be sitting at a desk---so we'll need a monitor at the least.
I was insisting on a 1440p 27" monitor for a more immersive gaming experience, but I was told recently that most games are made for 1080p and that this won't change for years to come, rendering a 1440p monitor for gaming pretty much useless. Is there any truth to this?
If this is the case then I might be willing to look at 1080p, which would leave me with enough money to buy a TV. If I can accommodate both in this small room. :)
Frugalmeister
Nope. I've been gaming at 2560x1600 on a 30" Dell for over 2 years now. The image quality and immersion at arms length is amazing. It's like watching a 55" TV from 6 feet away. Yes, some console ports don't look any better than they do at 1080P, but with the new gen of consoles I think this problem will fade away.
However, I think your money is better spent on getting both a TV and a 1080P monitor.
Old April 15, 2014, 05:15 AM
Bond007's Avatar
^^^Agree. With your needs you are going to want a TV and a monitor. Personally when sitting close I don't like 27" 1080p. Hence, why I recommend a 23-24" @1080p and then a TV (some people prefer the extra size of the 27, but when sitting close I find its just not enough resolution for that size).
Old April 15, 2014, 05:32 AM
ShinraCorp's Avatar
Frugalmeister
There is some truth to it, if it's a console port game then the resolution is limited. Normally any modern PC game will support higher than 1080p if your PC can keep up with it :P
Old April 15, 2014, 06:03 AM
My future PC will definitely be able to run smoothly with a 1440p monitor. Now I'm actually considering waiting to buy a new monitor until I can afford the new PC. Prices will have dropped by then. To be honest I couldn't even make use of 1080p with my current setup.
Thanks to all for your input. Separate monitor and TV seems to be the way to go!
Frugalmeister
Old April 15, 2014, 06:48 PM
JD JD is offline
If you are going to wait on the monitor front, you might as well skip 1440p and go to 2160p (aka "4K"). Samsung already has one out for $599 and prices should only continue to come down as production ramps up.
Depending what monitor you have currently, a 23-24" 1080p could still be an ideal upgrade in the meantime. Even if not for games, but general productivity since you'll be able to have multiple windows open side-by-side. Once you move up to 27"+ monitor, you can always keep the 24" as a secondary display.
Old April 15, 2014, 07:32 PM
You guys will laugh (a lot) but I have a 16" CRT monitor hooked to a 10-year-old P4 with 1 GB RAM. I can't even play 720p movies properly at the moment so I don't know how I imagined I'd be able to make use of a 1080p or 1440p monitor.
I think I'm gonna have to wait till I can afford my new gaming rig. No point in throwing away my money on something I can't use now.
Frugalmeister
  #19 (permalink)
Old April 17, 2014, 09:55 AM
JD JD is offline
Well in that case, if you have $600 available currently, even the cheapest PC at Best Buy/Future Shop paired up with a 23-24" monitor would be leaps and bounds better and far more enjoyable to use.
HP 110 Desktop PC (AMD A6-5200 / 1TB HDD / 4GB RAM / Windows 8.1) : Everyday Computing - Best Buy Canada
HP 23" IPS LED Backlit Monitor (23BW) : 23-24 Inch Monitors - Best Buy Canada
...but if your intentions are to move into the (expensive) world of PC gaming, then keep saving up.
  #20 (permalink)
Old April 19, 2014, 06:14 AM
Thanks for the suggestion JD. I most definitely want to wait till I can afford my new gaming rig. I just upgraded the RAM and there's a noticeable improvement. I'll get by with this old workhorse for now. :)
Frugalmeister
Asus PB278Q loses DisplayPort signal Triniman Troubleshooting 2 November 28, 2012 12:29 PM
ASUS Launches the PB278Q WQHD Display [techPowerUp] EmptyMellon Reviews & Articles from the Web 5 August 28, 2012 07:24 PM
BenQ XL2420TX Display Problems LegendofJubei Troubleshooting 8 May 13, 2012 09:12 PM
Thinking about 27" or Triple Display - advice please! zlojack Display Units 17 December 24, 2011 02:11 PM
