Old January 31, 2014, 03:42 PM
sakage.shinga's Avatar
Default Replacing my Dell U2412m lcd
My ips U2412m is giving me headaches while gaming. I never experienced this with my old hp w2207 so I'm assuming it's the monitor that's causing this. Any suggestions for a replacement?
I'd prefer to stay with 24" and more specifically 1920x1200.
Budget is $300 or so, preferably ips with good color reproduction since I use Photoshop quite a bit.
Thanks!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old February 1, 2014, 11:00 AM
LaughingCrow's Avatar
Can't suggest an alternative monitor, but do you wear glasses?
I wear bifocals and can get eyestrain from being at computer for any length of time. When I went to have my eyes checked recently, I requested subscription for non-bifocal glasses for arms-length viewing of computer monitors. I never had any problems with the old CRT monitors - I don't know if that's because the old monitors were much narrower than these wide LEDs or if it's something in the tech. However getting a prescription set for just sitting in front of the computer has helped a lot.
I've heard of special coated glasses that are supposed to remove glare from LEDs but have never tried them. You might also want to check lighting in the room to see if changing anything helps reduce glare.
Edit: BTW I have two computers with Dell U2412m monitors.
Old February 11, 2014, 05:20 AM
10e's Avatar
10e 10e is offline
The BenQ BL2411PT is a good alternative, but will be worth it only IF the issue comes from the PWM flickering you get from the U2412m's LEC backlight. Apparently the BenQ has a non-PWM based backlight that doesn't flicker. You can get these from NCIX and with a dead pixel warranty I would think (if you want that assurance).
You can try a test and run the monitor at a higher brightness for a little while and see if it helps, because higher brightness will lessen the PWM flicker. But don't go to an uncomfortable brightness, just increase it by a figure of 10-15 and see if that helps at all.
Old February 11, 2014, 06:44 AM
Skyllz's Avatar
To some it might sound gimmicky but try a set of Gunnars... they literally "saved" my gaming life. Prior to getting a set, I would get headackes from playing games on the computer or TV if I played more than 2 hours in a day. I have not gotten a headacke in a year since I wear these when I am sitting down for some serious gaming sessions.
GUNNAR Optiks - Advanced Computer Eyewear, Gaming Glasses, Prescription Eyewear
Is smoke supposed to come out of there?
Dell U2412m Ultima_weaponx Price Check 2 November 7, 2013 03:58 PM
Dell U2412M 1920x1200 IPS 3xploit Price Check 3 June 18, 2013 03:54 PM
New DELL display U2412M - Thoughts? MrDiaz Display Units 10 July 29, 2011 10:07 PM
