Old January 16, 2014, 08:37 PM
Rockfella's Avatar
Arrow Led blown?
I kept it on my dining table for 15 days due to some renovation. Now it looks like this god knows why..
Any idea what went wrong with it?
Old January 16, 2014, 08:53 PM
It was hit either on the front or the rear.. but from that image I would say the front.
You said you were doing "renovations"... I would say something from that renovation hit it.
Old January 16, 2014, 09:26 PM
SugarJ's Avatar
Looks exactly like my 46" Aquos did after my then 3 year old hit it with a plastic golf club. That's definitely an impact shatter.
Old January 16, 2014, 10:08 PM
KaptCrunch's Avatar
yes a nailer impact damage for sure
Old January 16, 2014, 10:15 PM
Birk's Avatar
DUDE
the girl from the ring tried to crawl out of it
THATS what went wrong with it
you best pass that one on to someone else
Old January 16, 2014, 11:43 PM
Rockfella's Avatar
Thing is the panel is not broken from front, looks like something is broken inside. Is this repairable? local tech say its gonna be very expensive.
Old January 16, 2014, 11:46 PM
Birk's Avatar
the screen might not be broken but the panel is. This would not be worth repairing.
Old January 17, 2014, 01:21 AM
SugarJ's Avatar
Bingo. My "protective" screen wasn't broke, but the panel underneath was. It was cheaper to buy a new TV than replace the panel. You'll probably find it's the same for monitors.
Old January 17, 2014, 11:24 AM
10e's Avatar
10e 10e is offline
Most LCD/LED TVs or panels will not show a cracked anti-glare coating because most 3H coatings are hard enough to be left intact in any except the most extreme impacts. They also have a high tensile strength and don't split or tear easy.
Turn it off and shine a light like a flashlight on it, and you'll likely find some form of a scratch near where the centre of that impact appears.
It was hit, and the panel is gone inside. You'll have to replace the panel, which likely will cost as much or more than the original item.
Old January 18, 2014, 11:46 AM
WiseWilson's Avatar
Sell it on an art board, You are a digital artist and you worked hard with many monitors to get this effect. You just need a catchy name and back story and it could pay for its replacement
EVGA GEFORCE 7600 BLOWN CAPACITORS Gameman Advanced Kid Video Cards 28 August 14, 2012 11:19 PM
Blown Bad Caps blitz Video Cards 9 January 10, 2012 04:04 AM
what would cause blown caps on a graphics card? FlyingFish Video Cards 6 August 7, 2011 01:05 PM
MSi R4890 Cyclone SOC - Prepare To Be Blown Away Soultribunal Press Releases & Tech News 1 September 21, 2009 07:49 PM
Blown Sound Card tmoses Audio 11 May 7, 2009 04:45 PM
