Old December 25, 2013, 10:46 PM
Spikemaul's Avatar
Default Help with Dell 2713H
I'm trying to get this monitor to display it's native resolution of 2560X1440 with no luck. I'm running Windows 7 Professional and have the monitor plugged into my GTX680 LIghtning with a DVI-D cable. The image turns to crap as soon as i bump up the resolution past 1920x1080. Help will be appreciated as I'm getting tired and frustrated......
Old December 25, 2013, 11:14 PM
lowfat's Avatar
Are you sure the cable is a dual link DVI-D? Replacing the cable is the first thing I'd try. Doesn't the display come w/ a DisplayPort cable?
Mael
Big Lian Li
Forever Alone
Old December 25, 2013, 11:39 PM
Spikemaul's Avatar
It was a DVI-D cable that I was using but it crapped out. I finally found the display port cable that came with the monitor and have zero issues now. The cable got mixed in with the son's electronics that he got for Christmas. I guess I should have waited until morning to set it up as the Rum n Nog would have worn off by then.
[WTB] Dell Inspiron 1545 or Dell studio 1569 laptop nork Buy/Sell & Trade 1 April 25, 2013 05:38 PM
Dell P2411H or Dell U2311H? MrDiaz Display Units 12 August 17, 2011 11:26 AM
dell to buy amd? coleo Rumor Mill 17 February 16, 2011 03:56 PM
Dell 2209WA $209 @ Dell MrDiaz Display Units 15 March 21, 2010 01:16 AM
A dell buy mailaw New Builds 2 November 27, 2008 07:04 PM
