Old November 23, 2013, 11:46 PM
Default 3x eyefinity, 2 new 1 old monitor?
Just throwing out ideas as I have yet to decide on the gpu's I'll be running in my new project. But I got to thinking it may be time for me to ditch the 20-30-20 setup for practicality and use. If I went to 3x30 things would work better on a nice crossfire 290/290x setup.
Now in the effort of saving a few bucks (i'll pause while you laugh) I wonder if I could keep using my (6+yr old) Samsung 305T as my center monitor (dp to dvi-d adapter) along with 2 new Korean panels on the sides that are native dp. This would also free up an hdmi port for 4th screen to an hdtv by using an MST hub. 7680x1600 :)
My main question is about matching colors/motion on the old samsun vs the new Korean panels. I'm not a big FPS gamer if anything its sims/strategy games but If I was to load up documents on all 3 screens am I going to go nuts to get the colors to match up?
Any help appreciated, I haven't bought a monitor in 6+yrs.
Have an A-1 day!
Old November 24, 2013, 03:00 AM
If you get a colorimeter, matching colors will be much easier. If you plan on running Surround or Eyefinity, however, only one color profile can be run at a time (Windows sees all displays as one display) so you'll be limited to what you can achieve through the monitors' OSDs. In desktop mode, you could create a separate profile for each monitor using a colorimeter and match the monitors well.
Old November 24, 2013, 10:07 AM
No matter how hard you try color will never match or be the same.
Old November 24, 2013, 10:47 AM
Bond007's Avatar
Yeah I have to agree. I tried for a long time to get a friends LG and a Samsung 24" to match with no luck (though it did end up close). And at work I have an Asus and a Phillips and they don't even come close...I leave the Phillips off unless I need it (no matter what I do it always has a washed out look to it).
Old November 24, 2013, 04:14 PM
b1lk1's Avatar
I have 3 lower end monitors bought at the same time and you can tell a difference between them irregardless of how much tweaking I have done.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old November 24, 2013, 08:41 PM
Default Now you tell me....
I have two 20" LED monitors on either side of a 24" LCD monitor. They are all LG's. What can I say Life's Good. . I bought the two 20" monitors for about $80 each on clearance on impulse not even thinking about things like colour match up - never mind different sized screens.
Software adjustments are a bust because as was mentioned the computer sees my 54" wide array as one big screen.
That leaves the monitor's individual control panels - and I have fiddled with those tiny buttons until the cows come home and I have not been able to get it to match up on all colours. Once I get the blues to be close enough across all three, the reds are off. Adjust the reds and the blues are off.
I've just got it 'close enough' and try not to let it get to me. In games I really don't notice it. The side monitors are mostly peripheral vision anyway.
I like to create 54"x10" panoramic images for my desktop - must have a 100 now. I stitch together several photographs I've taken for that purpose (use a tripod and rotate the camera, keeping it level for best effect). I've also created 54"x10" collages of images (My favourite one uses seven images of my grandson). Sometimes the colour variation is noticeable (e.g. the blue of the sky changes between screen) - other times it is hardly noticeable at all.
When I have an extra $150 or so that I don't know what to do with, I might buy a 24" LED screen and hopefully the colours will be closer. IF money were no object I'd buy a perfect set of three screens all identical and hope the colour was perfect and if it still was not perfect- which I've heard is a real possibility well then I'd be, well disappointed, big time.
BUT in the meantime enjoy what you have or can afford to have and don't let the imperfection spoil your day.
________________________________
FKD
Fort Kent, Alberta
2012 - A10 Rig
Old November 24, 2013, 08:53 PM
I used printscreen to create this image but I don't think that accurately reflects the colour variation, in this particular image the differences are not bothersome.
In case you are wondering, this one is from one of our quadding trips.
FKD
Fort Kent, Alberta
2012 - A10 Rig
Old November 26, 2013, 07:24 AM
b1lk1's Avatar
Printscreen just gives a copy of the render, not the actual images the screens are displaying.
Best Monitor for Eyefinity FrostbittinHD Display Units 1 December 20, 2012 07:37 PM
Here it is.. What is the best 24" 3 monitor set up for Eyefinity Fuel4Life Display Units 0 December 7, 2012 05:57 PM
eyefinity monitor suggestions jtktam Display Units 5 February 21, 2012 02:59 PM
Eyefinity/ 3 monitor questions wayner Video Cards 1 February 1, 2011 02:17 PM
eyefinity on T240 monitor? hatabilly0204 Display Units 6 December 10, 2009 09:04 PM
