Old October 20, 2013, 01:56 PM
Default Should I install the driver for my monitor?
I have purchased a DELL U3014 and SLI Titans. Should I installed the driver for the monitor or just plug and play?
Old October 20, 2013, 03:58 PM
Jake_HT's Avatar
yes .
http://jakeht.deviantart.com/
Old October 20, 2013, 04:53 PM
Originally Posted by Jake_HT View Post
yes .
Why? I never have. The only thing installing monitor drivers MAY do is install a ICC profile that of which most people wouldn't even notice a difference.
Most monitors are all plug and play these days.
Old October 20, 2013, 05:31 PM
Cool, thanks for info
Old October 20, 2013, 07:16 PM
KaptCrunch's Avatar
if you did you will see a big difference in gaming for the color shading corrected
Old October 20, 2013, 07:26 PM
Again MOST people would not notice this.
Old October 20, 2013, 07:27 PM
sswilson's Avatar
I install them based on the issues I've had running HDMI connections from Nvidia cards.
Old October 20, 2013, 08:03 PM
Bloodystumps's Avatar
yup I had these issues before.
Old October 20, 2013, 08:43 PM
Now I just have to decide what I am going to use for a medium between GPUs and monitor. Should I use HDMI, DVI or Display Port
Old October 21, 2013, 09:37 AM
ShinraCorp's Avatar
Honestly for the monitor driver, I experienced no difference with it, heck I just let Windows Update do it for me just because... As for your cable it's best either using DisplayPort or DVI, HDMI as far as I know is simply to use your monitors speakers (if they have any) since it's both audio and video signals inside an HDMI cable. DisplayPort (I don't have one so I may be wrong on this) is allowed to "Daisy-chain" multiple monitors with only 1 cable, so you only need to plug 1 DP cable to your PC while other cables to each monitor. My set up is one has DVI, the one has HDMI (it was a spare cable lying around, and the monitor only came with a VGA cable). Yes I only have two monitors so I can't use NVIDIA Surround or anything like that but my desk forbids me to have enough space for a 3rd one lol.
NVIDIA OpenGL driver lost connection with the display driver kr7777 Video Cards 0 October 1, 2013 09:44 PM
No physix drivers installed after I installed them? Help!! bushwickbill Video Cards 8 February 14, 2013 08:23 AM
New CPU Installed Error message qlix Troubleshooting 3 August 5, 2012 08:26 AM
System installed ! FrankyG Water Cooling 14 October 10, 2008 03:33 AM
has anyone installed OSX on a non-Mac laptop? Mr. Friendly Mobile Computing 3 April 19, 2008 12:21 PM
