Old September 16, 2013, 08:12 AM
Alpine's Avatar
Default unable to do 1080P from PC on my TV
Hello guys,
This w/e i have buy a Samsung UN55F6800AFXZC. Everything is fine. I cablirated the color with my Spyder4elite and its awesome.
The only problem i have, i can't have 1080P working from my multimedia PC. I can only do 1600 X 900.
I have update the driver, changing my hdmi cable and using another hdmi connection on the new tv.
The video card is a ATI radeon 6450, which was working in 1080P on my older 40'' screen.
Next thing to do ... upgrading the firmware of the tv ? !
HHEELP !!!!
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old September 16, 2013, 10:01 AM
"Quote This..."
That is strange, you may have to get an updated .inf file for that TV.
Old September 16, 2013, 10:12 AM
Alpine's Avatar
That .ini file is suppose to be in the drivers right ?! So, it might bad/ corrupted ?
Main system
Server system
Old September 16, 2013, 10:23 AM
"Quote This..."
I've never had to install drivers for any TV. May be firmware in the tv. Or maybe you can edit the .inf and add 1080p 60hz. I've got a Sammy 65" and it worked out of the box with 2 HTPCs and a Denon Receiver in the loop.
Old September 16, 2013, 10:46 AM
Alpine's Avatar
I was thinking that was because the drivers of the video card.
Im gonna try with a update of the firmware
Main system
Server system
Old September 16, 2013, 12:41 PM
Oversized Rooster's Avatar
I have never had to install a TV driver in my life when trying to output 1080p.
You have a $1500 TV and a $35 video card.
I would try replacing that video card as a first step. Try another video card via HDMI and let's go from there. I am willing to bet the problem is not on the TV side. After all, TVs are "dumb devices" from the computer's perspective.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old September 17, 2013, 05:38 AM
Alpine's Avatar
I found the bug in the control center in the driver from the video card. There was a upscalling option that wasn't setup correctly.
Main system
Server system
Unable To Share Networks?! AdamHuw Networking 3 September 21, 2012 11:14 AM
Unable to acccess Google? Lpfan4ever Off Topic 12 August 12, 2009 08:21 PM
unable to OC BrokenHalo83 Troubleshooting 8 April 6, 2009 11:09 AM
Unable to overclock Computergeek Overclocking, Tweaking and Benchmarking 1 July 11, 2008 04:17 PM
