Old June 11, 2013, 02:29 PM
Your_friendly_gamer's Avatar
Default How to calibrate monitors?
Hey all,
I have never calibrated the colors on my monitor before. I have heard about and would like to do so. Is there a program and software that I cna download to do so? I have DELL ST2320L. Any advice would be great. Thanks.
Old June 11, 2013, 03:08 PM
sswilson's Avatar
Windows has a built in utility that adjusts things like brightness, contrast, and sharpness, but if you want to do a proper job you need to get a hardware solution as opposed to a software solution which is subjective at best.
Old June 11, 2013, 04:28 PM
WhippWhapp's Avatar
DVE or Avia does a passable job for those not photo editing.
I rub and whack and choke and stroke!
Old June 11, 2013, 05:14 PM
KaptCrunch's Avatar
need the file.ICM for you moniter if manufacturer has drivers and put in colour management
dell drv DELL_ST2320L-MONITOR_A00-00_R299044
Old June 12, 2013, 06:14 AM
I use ColorVision's Spyder2Express (very old model). You can probably get a cheap used one. It works on win7 with its own software. I also use the hardware part to calibrate in Linux/debian using the free Argyll software.
BTW, I need to calibrate because I process photo images. For the games, you do not need it, since most games would kick it out before starting(at least that is the impression I get, but not sure)
Old June 12, 2013, 09:00 AM
dandelioneater's Avatar
I've used the spyder express as well. It seems to do an good job. It gives you a color profile which is applied to the video card. I'd rather have a hardware solution that i could use to calibrate a tv or any other screen that doesnt use software but this is fine for a PC.
how many monitors do you use? muse108dc Display Units 27 March 6, 2013 09:28 AM
sli with 3 monitors gingerbee Display Units 11 May 17, 2012 10:40 PM
What monitors to get? SKW Display Units 8 August 1, 2011 03:28 PM
2 monitors, what to do muse108dc Display Units 3 May 26, 2011 08:13 PM
How do I calibrate my computers monitor? Shadowmeph Display Units 22 September 7, 2009 12:40 PM
