Old May 13, 2013, 03:12 PM
Brian's Avatar
Default Anyone have info on getting replacement adapters?
Through circumstances regarding moving and family members I've got my hands on a 27 inch Acer monitor and with a new video card would love to use it, but no power adapter for it. Does anyone know a way of getting a power adapter aftermarket, or an Acer replacement adapter?
Thanks.
Old May 13, 2013, 03:24 PM
I just searched Amazon and there are some replacement adapters. Of course you do risk going with 3rd party instead of original Acer. I did it with my Canon 5200F scanner and so far so good.
Old May 13, 2013, 04:35 PM
Brian's Avatar
The only ones I can see (quick search, hockey game is on) are AC adapters and the monitor power port says DC in.
Old May 13, 2013, 08:56 PM
OK, I'm not 100% sure but I'm think they are all AC to DC adapter. To be 100% sure, use the monitor model number and read the reviews.
Input: AC100-240V (worldwide use)
Output: DC19V 3.16A,Power: 60W
Amazon.com: Acer AL1703 AL1714 LCD Monitor AC Adapter Power Supply Replacement: Computers & Accessories
Old May 14, 2013, 11:33 AM
Brian's Avatar
I got some info off the back of the monitor and the power rating is 19V - 2.1A(2.1A)
That power supply you linked on Amazon puts out 3.16A. Most adapters I've looked at have a range and protection against sending too much through. Is it safe to assume that one does as well?
As well I'm not sure about the wattage I don't have any info on how much the monitor uses and don't know if the adapters I'm looking at have enough.
Old May 14, 2013, 02:42 PM
I'm just pointing out an example. Without the exact model of the monitor, you are just lost in the dark. Don't even think about using something that doesn't match the required power rating. What is the model of your LCD anyway? You could just call / email Acer and ask about a replacement adapter, just make sure they give you the adapter's model number so you can go back on Amazon to look for a 3rd party replacement.
Old May 14, 2013, 03:04 PM
Brian's Avatar
It's the H274HL bmid. I have been looking. That adapter does match the power requirements and is the first one I've seen that doesn't have specs about the ranging and controlled amperage. (ie. 1.5 or 1.9-3.5A) Other than that it would work fine. The only ones specifically for this model I've seen are through junk sellers on eBay hence looking at ones that match power requirements rather than specific models. Aftermarket replacements seem to be limited to smaller model monitors or netbooks.
I've contacted Acer but as expected from a company like them, no response.
Old May 14, 2013, 03:10 PM
3.0charlie's Avatar
Acer LCD Monitor H274 AC Adapters - acerparts.ca
New Genuine Acer Replacement Lcd Monitor Ac Adapter Power Cord 40 Watt
Genuine Acer FHD2303 H274 S201 S211 S212 ADP 40PH BBH LCD Monitor 40W AC Adapter | eBay
Should all be fine. Model number seems 'AP.04001.003'.
Hydro-Quebec is salivating...
Old May 14, 2013, 03:33 PM
Correct me if I'm wrong but for monitors, as long as the adapter outputs equal or more than what you need, you're fine.
Old May 14, 2013, 04:18 PM
Arinoth's Avatar
That's actually the maximum current it can output, meaning any device that needs 19V while plugged in can pull up to 3.16A but will pull less if it doesn't need more
Here I am: here I remain
Power Adapters Generic User #2 Power Supplies 6 December 4, 2012 10:23 PM
[WTB] Amarthfea's WTB! G19, 3x fan cable adapters Amarthfea Buy/Sell & Trade 31 November 28, 2011 06:02 AM
Powerline adapters & routers miggs78 Networking 6 December 10, 2010 11:05 AM
Questions about (Tri) SLI and Pin Adapters bkh2 Video Cards 7 June 9, 2010 08:45 PM
USB vs. PCI Wireless Adapters Shimakaze Networking 13 April 17, 2010 11:13 PM
