Old May 7, 2013, 02:04 PM
Caldezar's Avatar
Default DELL U2713H Serious colour issues!
I just set up my new DELL U2713H and for 30 glorious seconds I was amazed. Then the colour problems started and are driving me crazy! Basically the monitor flips around it's colour hues from a bluish 'cool' tint, all the way to a warmer tint. It happens all the time and no matter what I'm doing. (Gaming, desktop, etc.) I didn't have any problems with my U2312HM's at all. So I switched from the D.Port to DVI, with the same results. So then I moved off sRGB on the monitor and tried standard AND a custom setting. All with the same results! Final step was to record it happening in FRAPS during a game, but the fraps video does NOT reflect the issue. This means it's happening at the monitor side, not from the PC.
Any thoughts? Or am I stuck calling DELL pissed off...?
Uploaded some iPhone clips of it happening to demonstrate the issue:
*EDIT* - Videos were flagged as duplicates of each other on youtube for some reason, so I removed them. Issue resolved now anyway. (Thanks AKG)
Old May 7, 2013, 02:38 PM
I think I can see it happening at 0:07 and 0:10, correct? Does it fluctuate between only two different hues or is there a wide range of fluctuation? Did you eliminate the possibility of a Windows color profile problem?
Old May 7, 2013, 04:37 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Go to Display Settings ->Smart Video Enhance...and turn it OFF.
This should fix the problem. ;)
Old May 7, 2013, 10:22 PM
Caldezar's Avatar
BOOM! You're my new hero! Fixed the issue. That has to be the WORST thing to flag as a default option on a monitor!
And now I'm loving life in 1440p! With that resolved, this is hands down, the best monitor I've ever used.
Dell UltraSharp U2713H 27” Monitor Review Comment Thread SKYMTL Display Units 13 April 17, 2013 02:39 PM
[FS] Nook Colour $115 [nK]Sharp Buy/Sell & Trade 2 May 9, 2012 11:25 AM
Colour Calibration? dragoonxx Display Units 17 November 4, 2009 07:47 PM
Case Colour BALISTX Cases 11 May 3, 2007 07:12 AM
