Old April 23, 2013, 07:49 AM
Caldezar's Avatar
Default Upgrade From Dual 1080p to Single 1440p?
So after reading up quite a bit on the U2713H, including SKYMTL's review here, I'm seriously thinking about upgrading from my current setup. I'm running two U2312HM's side by side. They have been outstanding monitors, and a dual monitor setup makes a HUGE difference for work productivity. (My gaming rig also serves as my home office/work PC)
I'm curious to hear what people's thoughts are on moving from a dual 23" 1080p setup to a single 1440p 27". I know that gaming will obviously be a great leap forward, but I'm also thinking about work environment, day to day, etc. I'll lose the extra screen, but gain quite a bit of real estate on a single screen. Overall this loses me screen space, but how much really? And there something to be said for staring straight forward at a single screen.
Before people suggest keeping my 2 monitors in addition to the new one, that's not really an option as I would sell them to recoup a bit of the cost of switching.
Thoughts?
Old April 23, 2013, 10:25 AM
KaptCrunch's Avatar
or go with projection after selling 2 moniter and zero real estate
Old April 23, 2013, 10:36 AM
lowfat's Avatar
I've always preferred a larger single display over two slightly smaller displays.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 23, 2013, 11:41 AM
Ravenor's Avatar
I have always preferred a single monitor setup as well. To keep productivity flowing, you could always sell the 2 smaller monitor's get a bigger one and sometime down the road pick up a cheap smaller lcd as a secondary monitor.
Roy: [singing] We don't need no education.
Moss: Yes you do; you've just used a double negative
Old April 23, 2013, 11:56 AM
Really depends on personal preference and your workflow.
My long-term plan is to move from my dual 24" 1920x1200 to a 4K 30" monitor with a secondary 1080p 21" monitor in portrait mode.
Old April 23, 2013, 12:49 PM
Caldezar's Avatar
Hmmm... I'm doing more research and I'm finding a lot of reviews and such pointing me to the Asus pb278q. I'm gonna need to do more reading on that monitor as well.
Old April 23, 2013, 11:11 PM
bigFOIG's Avatar
You can fit more stuff on 1080p x 2 than 1440p. I used to run on dual 24's and then ran a single 27" 1440p. The IPS panel was so much better than my old TNs but I found myself missing a second monitor quite often. 2 monitors is much better for productivity than 1 monitor as I'm sure you already know.
Now I run an IPS 1440p alongside one of my old 24" 1080p's and I have everything I need. Soon to upgrade the 1080p into another IPS 1440p when I have the money.
Here's how I see it. If your set up is strictly for productivity, IMO your set-up now is better. If you want better picture quality and better entertainment experience, go with your Asus 27".
I know you said that you can't keep all the monitors, but how about keeping one? A 27" PLS along side one of your existing 1080p's should be the best option. Best of both worlds?
Old April 24, 2013, 06:42 PM
muse108dc's Avatar
For me personally I currently have a 3 monitor setup with a 22 in the mid, 20 and 17 on either side an am planning on moving from the 22 to a 27 and keeping the other 2. So its a bit simpler for me but is there a reason you won't be keeping either of you older monitors as a secondary?
You will be loosing some real estate for sure but in my experience a bigger primary is better than splitting it between 2 smaller displays.
Old April 24, 2013, 06:55 PM
Supergrover's Avatar
Agreed, I went from a 3x 22 to a 27 and ended up having to add a 22 back into the mix, (portrait mode mind you, works pretty good alongside my U2711) once you go from a multi-monitor setup to a single it is hard to get used to, I hated having to minimize what I was working on or flipping through windows.
R.I.P.
Old April 24, 2013, 07:06 PM
Shadowmeph's Avatar
How would one do that what I mean is what would a person need to have a decent setup what are the pros and cons?
Need dual 1080p monitors, low budget. TheWildRose Display Units 5 January 4, 2013 06:08 PM
Dual 3GB 580's now, or a single 680? AmuseMe Video Cards 5 June 3, 2012 10:39 PM
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Dual 1080p on Windows 7, multi monitor noob 0o0 Display Units 4 March 14, 2010 02:39 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
