Old February 21, 2013, 09:27 AM
Slik's Avatar
Originally Posted by JD View Post
Since the horizontal resolution is the same between this 29" and the 27/30" monitors, I don't see why it wouldn't look as sharp/crisp. The height is just going to be much shorter compared to the 27/30" monitors.
It'll obviously look funny at first if you come from a 16:9 or 16:10 monitor, but eventually you'll get used to it. I imagine this would pretty much fill your FOV.
21:9 is what most movies are done at I believe? I know there's been 21:9 TV's launched in Europe and Asia.
Thanks JD. I'm going to get one,and go from there for a decision on whether to hook up three of them. 21.9 IS the ratio for movies. As soon as the 21.9 aspect ratio televisions are available,I'm getting one. They should have built those things years ago.
Thermaltake Level 10-i7 3930k @ 4.2ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 1600mhz- Two EVGA Titans SLI - Xonar Phoebus Sound Card-Dell 3008 30" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old February 21, 2013, 09:26 PM
dustin1706's Avatar
I freaking love these super wide monitors. For a decade now I've been using dual monitors: Primary and Secondary. I tried triple monitors, but the bezels really ruin it for me. If these ever come out in like a ~40" I will pick one up for sure.
Fullscreen gaming/movies and simulated dual screen for productivity.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old February 22, 2013, 07:02 AM
Slik's Avatar
I changed my mind guys. After re-reading the specs,I found the actual viewing area is way too small for gaming. The screen is wide enough at 27.30 inches,but the height is only 12.16 inches. That simply does not compare to the 25x 15.50 inch viewing area on the 30 inch I have now. That extra 3 inches in height really makes a difference. So much for that.
Old February 22, 2013, 08:23 AM
10e's Avatar
10e 10e is online now
As a fellow 30" owner, and a former user of a 3008WFP which I absolutely LOVED, you made the right choice.
Basically with one your field of vision will only fill horizontally, and the vertical resolution will be too small for both gaming and desktop use. The immersion versus a 16:10 30" is severely less.
Old February 22, 2013, 02:50 PM
tangrisser's Avatar
Originally Posted by enaberif View Post
2560x1080 personally would be like dating a 300lb 4'5 woman; To wide and not enough height.
If this was facebook, this would get my Like.
Check out my SALE page
[WTB] Dell 2007 FP monitor ITaoI Buy/Sell & Trade 1 January 6, 2013 05:45 PM
Where to buy Dell 24" monitor ? Patriote Display Units 3 July 25, 2007 06:52 PM
