<~----> Laptop to dual link DVI monitor? - Hardware Canucks
Old January 11, 2013, 04:12 PM
bigFOIG's Avatar
Default Laptop to dual link DVI monitor?
I have a laptop that has a G210m video card and has HDMI out. I also have a 2560x1440 monitor which only has dual-link DVI. I've done some research but I just can't get a definite answer. I believe my HDMI port is version 1.3 which supposedly works with 2560x1440.
Will a simple HDMI to dual link DVI cable work? Or do I need an active cable of some sort? Or will it not work at all?
I know that performance on a resolution that high with this GPU isn't going to be the best, but I won't be gaming or anything like that on it. The power should be sufficient to surf the web.
Old January 11, 2013, 05:00 PM
As far as I know, you don't need any kind of converter to do DVI to HDMI so I assume it works the other way as well. My HTPC uses a DVI to hook up to a Samsung TV using one of those DVI-HDMI cable. The cable itself doesn't say anything direction / connection restriction. The cable isn't expensive so it doesn't hurt to try.
Old January 11, 2013, 05:17 PM
bigFOIG's Avatar
Well I know that DVI and hdmi work together easily. But in my case, my monitor is dual link dvi and the resolution is higher than HD.
Old January 11, 2013, 06:50 PM
If the Wiki article is correct, it looks like you may not get as high of a resolution to display on the monitor. Also, from reading this thread, you won't be able to max out the monitor resolution.
Digital Visual Interface - Wikipedia, the free encyclopedia
Gefen Forum - HDMI 13b to DVI Dual Link 2560*1600
[WTB] Dual-Link DVI-D Cable great_big_abyss Buy/Sell & Trade 2 December 26, 2012 07:28 AM
Single vs Dual Link DVI (argh!) hfxmike Video Cards 23 June 2, 2011 06:18 PM
Problems with Telus' D-Link D-link DVA G3810BN - extra router? chartkor Networking 8 January 3, 2011 11:55 PM
Dual-Link crossfire hookup for 2560x1600 Dogger1 Display Units 2 November 21, 2010 06:38 AM
dual monitor help EaGle1337 Display Units 5 February 3, 2009 05:39 PM
