-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   Need dual 1080p monitors, low budget. (http://www.hardwarecanucks.com/forum/display-units/58921-need-dual-1080p-monitors-low-budget.html)
TheWildRose January 4, 2013 03:52 AM
Hello everyone, I'm looking for a new pair of monitors for my gaming/workstation rig.
I have a kind of tight budget for what I need though.
Requirements:
- 1080p
- 5ms response time
- LED Backlit
- At least 21.5-inch viewable
Budget $300 for two, I can probably do $350, but I want to keep it as low as possible.
Thank you so much in advanced for the help, I've been reading monitor reviews for 3 hours now, I just cant find a decent monitor to trust.
nox404 January 4, 2013 02:46 PM
Best Monitor I have ever purchased
I have one at home and two at work. A buddy of mine picked up two for home with no problems.
Amazon.com: ViewSonic VX2250WM-LED 22-Inch (21.5-Inch Vis) Widescreen Full HD 1080p LED Monitor with Integrated Stereo Speakers: Computers & Accessories
PS. Do not use the integrated speakers they are crap.
Rollergold January 4, 2013 04:12 PM
Requirements:
- 1080p
- 5ms response time
- LED Backlit
As a starting point I suggest the Asus VE228H or if your willing to go the non LED route the Asus VH236H.
Newegg.com - Asus VE228H 21.5" Full HD HDMI LED BackLight LCD Monitor w/Speakers ASCR 10,000,000:1 Out of stock atm
Newegg.com - ASUS VH236H Black 23" 2ms Full HD Widescreen LCD Monitor w/ Speakers 300 cd/m2 20000 :1 (ASCR)
supaflyx3 January 4, 2013 04:14 PM
BenQ G2222HDL. I have one and its a really good monitor, i think i paid $150 for it, 21.5".
TheWildRose January 4, 2013 05:44 PM
As for the BenQ - It seems to be discontinued.
But the price on the ASUS is unbeatable, And it has HDMI support (Which I probably won't use for a bit, Just the inc. DVI cables) And on Amazon it's $135, My local shop can get them, for $130!
If anyone is interested the link is: Amazon.com: Asus VE228H 21.5-Inch Full-HD LED Monitor with Integrated Speakers: Computers & Accessories
Thanks everyone for the help and recommendations. The reason I needed the new monitors is where I'm buying from (Locally) The Dell monitors I was going to get shot up to $200.
Anyway, thanks guys!
[/THREAD]
supaflyx3 January 4, 2013 06:08 PM
Mike's Computer Shop - BenQ G2255 21.5" LED LCD Monitor - 16:9 - 5 ms That's pretty much the same monitor I have.
