-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   Best monitor Tv (gaming - entertainment) (http://www.hardwarecanucks.com/forum/display-units/58000-best-monitor-tv-gaming-entertainment.html)
Athatag November 21, 2012 04:04 AM
Hi Guys, I have a question about monitors!
I play with a gtx 560Ti twin frozr II from MSI on a resolution thatís 1440x900, so I want to change my monitor to a better one. Iíd like to use a 24Ē (not 27Ē because I think that 1080p for it isnít enough, am I right?)
My question is about which monitor I should chose: I would like to buy a monitor TV, of course I donít need the maximum, but I good experience in gaming so I would like to find a good monitor that has got a quite good TV. I saw the LG m2452d that has got also the IPS panel with a good viewing angle. I found very few review and different opinions about its use for gaming. What would you recommend to me? Do you think that other monitors TV from for example Samsung would be better or even something else?
Waiting for your answer, Ty. :biggrin:
SKYMTL November 21, 2012 05:48 AM
It really depends on your needs. How far away from the monitor / TV do you expect to game? If less than 6ft, you will certainly want a regular monitor. Anything beyond that, an HDTV starts becoming a possibility.
Athatag November 21, 2012 07:15 AM
Yes I play at a normal distance from the monitor at less than 6ft
SKYMTL November 21, 2012 07:42 AM
In that case, a monitor would be your best bet since at anything above 27", the 1080P resolution of an HDTV would result in an extreme loss of detail and image fidelity at that distance.
What is your budget?
Athatag November 21, 2012 10:05 AM
I think 250/300 Ä max! Which monitor tv wuold you raccomend me?
SKYMTL November 21, 2012 10:47 AM
Personally, I'd go with the Dell U2412M or ASUS PA248Q for that price.
