Old October 28, 2012, 12:18 PM
Default Response Time
Hey everyone! I recently ordered a Benq GW2250 VA panel mointor. I went with this monitor because I watched LinusTechTips do an unboxing of a monitor from the same series. He said that you should go with any panel except TN. So I read up on the panels and it turns out that VA panels have good color and they are relatively cheap, BUT they can have slow response time. I am wondering if I will see any ghosting on the monitor and if so, What is a "safe" response time to go with in the future? Thanks!
Old October 31, 2012, 12:05 PM
10e's Avatar
10e 10e is offline
No such thing as safe response time, as most manufacturers pretty much just lie.
Some monitors listed as a 2ms response time achieve that through RTC/response time compensation, and this can cause overdrive artifacts like reverse color ghosts that are obvious during normal image movement. So then you turn off the RTC/overdrive and they are super-blurry. Other monitors listed as 6 to 8ms may be faster in most color transitions.
The AMVA panel in this monitor should be sufficient except possibly for dark games where MVA/PVA is known to have issues. Right now the GW series from BenQ is pretty fast most of the time otherwise, so it should be pretty good.
Old November 1, 2012, 03:14 PM
I have the same monitor at my house, and its really a great transformation. The vivid colors will make up for the "ghosting" that people see in slow response time monitors. Just go for it, and enjoy the moment.
Tags
benq , monitor , panel , response , va panel
Intel Smart Response Jamz Storage 2 October 31, 2011 03:59 AM
Help setting up my first SSD under SMART RESPONSE Valamyr Storage 2 August 21, 2011 08:27 AM
Fastest response time, large screen monitor? 3.0charlie Display Units 20 December 2, 2010 01:29 PM
'No Russian' - An emotional response - MW2 Review mattlef Member Reviews 78 January 31, 2010 11:10 PM
Response Time or 120Hz? AmuseMe Display Units 9 January 31, 2010 12:59 PM
