-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   i am planning to do nvidia surround..... (http://www.hardwarecanucks.com/forum/display-units/56875-i-am-planning-do-nvidia-surround.html)
akhiltu September 23, 2012 05:44 AM
i am planning to do a nvidia surrouns setup do i need to go for
1.3d ips monitor's
2.120hz ips monitor's
is there any monitor is ips,3d,120hz ?
i planning to get 3 of them 24 inch 1920*1080
please suggest me a good monitor
thank you advance
supaflyx3 September 23, 2012 05:51 AM
There are very few 3D IPS monitors, the few there are, are very expensive and aren't worth it. You're stuck with either 3D or IPS. My suggestion would be 3 U2312HM's.
draemn September 23, 2012 07:06 PM
IPS is pretty damn nice to use with surround as you do create some odd viewing angles at times. I really don't suggest 3D surround unless you have high end graphics such as a 690, 2x680, 3x670, or 3x580/570 already installed on your computer. You really can't go wrong with a Dell IPS monitor, there are better, but everyone I know who owns a Dell IPS is extremely happy with them.
Dzzope September 23, 2012 08:28 PM
one or other unless you have far, far too much money..
24" on ips will be 1920x1200, which is actually a much better aspect ratio for pretty much everything other than watching movies.
You can find some 100hz ips I believe but really you are much better going for 1 or the other at the moment..
