Originally Posted by Skippman Which would work great, if my computer wasn't behing me. I needed a 20ft cable. Ended up getting a 25' dual link DVI cable for $25 at Micro Center. Working great now! All I'm waiting for is that 20ft USB 3.0 cable to come in. Don't worry, it has a built in repeater. I just wish this thing had the media card reader the U2711 does. Seems kinda odd the left it off. |
Ahhh, the cables always do seem too short even when the machine is right there.
Originally Posted by muse108dc I'm looking at getting this model some time fairly soon I think but I'm curious as to the difference between a full 16:10 ratio monitor and this being a 16:9. Will I notice it going from a 22 to a 27 first of all.
And I do plan on using this for my main gaming monitor as well, should I expect to notice ghosting coming from a 2ms response time or is it really a non issue at this point? |
I doubt you will notice a change going to 16:9 but that is because of the high resolution on this one. Cause no matter what 22 you have you will be getting quite a bit more vertical resolution than you had before.
