I have never seen a monitor that does not tilt. this off their website "Unfortunately no tilt despite the website saying it has one. Otherwise excellent." which is stupid imo.
And what is Samsung Magic Angle? I am going to look into this further.
Viewing angle: The optimal viewing angle for a monitor is usually directly in front, about a quarter of the way down from the top of the screen. At this angle, you're viewing the colors and gamma as the manufacturer intended. Most monitors are not made to be viewed at any other angle. Depending on the panel type, picture quality at nonoptimal angles varies. Most monitors use TN panels, which get overly bright or overly dark in parts of the screen when viewed from nonoptimal angles, making for inaccurate color representation. The Samsung SyncMaster B2330HD uses a TN panel, and when it is viewed from the sides or bottom, we perceived the screen as darkening about 6 inches off from center, which is typical for a TN.
To help out with this somewhat, Samsung includes the Magic Angle feature in the B2330HD. The Magic Angle mode prevents the screen from darkening when viewed from certain angles. Magic Angle has four settings: Lean Back Mode 1, Lean Back Mode 2, Standing Mode, and Side Mode. Switching to each mode will improve screen brightness when viewing the monitor from that angle. For example, after switching to Lean Back Mode 2 and then sitting back in your chair to play a game, the screen doesn't darken nearly as much, and as a result, game details can still be seen, while you do irreparable damage to your spine, all in the name of "fun."
