Old August 19, 2012, 02:38 AM
Default DVI-D Single Link On VG236H
I just bought a used Asus VG236H off Craigslist. I tested the monitor with an HDMI connection and it worked fine. The seller did not include a DVI cable. When I got home, I hooked up the monitor to my gtx 670 with a single link DVI cable but the monitor says there is no signal.
Shouldn't the monitor get a signal from DVI even if it's only single-link? I'm sure the cable is good since it works with my old monitor. I don't have a dual-link cable to test with.
Does anyone have an insight into this? Sure hope I didn't get suckered.
Old August 19, 2012, 02:55 AM
Supergrover's Avatar
IIRC that is a 3d monitor and as such will most likly need a D-DVI cable........ yup just googled the Monitor and it recomends D-DVI or HDMI.
If it runs fine on hdmi and you have the cable use it and call it a day, or if you really feel the need grab a quility D-DVI from Monoprice or when they are on a good sale, cables have the most god aweful upmark out there. IIRC there was a recent post asking if member wanted to add to a sn members monoprice order ( shipping from Mono can be pricy but if you are buying multiple item from them then the pricing is quite good.
I always try to make at least a 200 order when I do order just because of the shipping, 1 item is rape but as you add more to your cart it gets reasonable.
R.I.P.
Old August 19, 2012, 03:21 AM
If I'm not mistaken, I can't get 120Hz on single link DVI nor HDMI. From the manual, I can only get 120Hz from DVI, which is what I originally bought the monitor for.
Old August 19, 2012, 03:51 AM
Then looks like a D-DVI cable is needed, though I thought hdmi 1.3 and up could do 120 at that res, hell I thought 1.3 was good to 240 at 1080. But I am guessin gthat is a monitor limitation rather than a cable limitation. YMMV
R.I.P.
Old August 20, 2012, 12:24 PM
I'm going to grab a dual link dvi cable later today and give that a shot. As a sidenote, I hate how cables are marked-up 150%. Really, $25 for a dvi cable?
Anyway, I have a feeling I'm out $x amount of dollars and have no 120Hz to show for it.
Old August 20, 2012, 01:54 PM
Arinoth's Avatar
You can order them cheaper from monoprice, but unless you're buying quite a few things it's not really worth it due to the shipping.
Here I am: here I remain
Old August 20, 2012, 01:57 PM
They are cheap to obtain indeed and you will feel an amazing difference if you came from a 60hz, i have the GD245HQ and im happy with it.
Old August 21, 2012, 02:54 PM
Thanks guys. I found a local vendor that doesn't gouge you as much as NCIX, et al. Atic.ca to the rescue :)
Anyway, to answer my question for the benefit of anyone who runs into the same problem, yes, you can run a VG236 with a single-link DVI cable. You're technically limited to 60Hz @ 1080p but you can still make the OS send a 120Hz signal to the monitor - it's just not going to look pretty.
ASUS VG236H Issue Finkswitch Display Units 1 October 30, 2011 12:06 AM
Single vs Dual Link DVI (argh!) hfxmike Video Cards 23 June 2, 2011 06:18 PM
Problems with Telus' D-Link D-link DVA G3810BN - extra router? chartkor Networking 8 January 4, 2011 12:55 AM
Looking for Asus VG236H in Canada wildbohr Display Units 5 August 4, 2010 06:04 AM
Forcing Single-link DVI output xilocient Video Cards 1 May 5, 2010 05:26 AM
