Old August 17, 2012, 08:24 PM
Default Super tight budget monitor
So my buddy is building a rig and he needs a monitor for under $150... I really don't know much about display units at all and really my eyes aren't fantastic anyways so to me it isn't a huge deal but I don't want to suggest a crap monitor for him.
Old August 17, 2012, 08:53 PM
Adzsask's Avatar
I picked up two for under $150 shipped one was a 21.5 inch hanns g, and the other was the same size, only hannspree brand name. Both going over 2 years strong. Both are 60Hz LCD backlit, 1080P.
Old August 18, 2012, 04:18 AM
Unfortunately buying from ncix good suggestion though.
Old August 18, 2012, 07:47 AM
This ips monitor is on sale at ncix for 160. LG IPS224V-PN 21.5IN Widescreen LED Backlit LCD Monitor IPS 1920X1080 5MS 5M:1 VGA DVI HDMI - LG Electronics - IPS224V-PN Not sure how the quality is as I don't have any experience with it. However my ips monitor looks significantly better than my old tn panel one. I would suggest that your friend go look at monitors before purchasing one. That way he can pick which one he likes best.
Old August 18, 2012, 08:38 AM
sswilson's Avatar
Acer S240HL Bmii 24IN Widescreen LCD Monitor 1920X1080 LED Backlit 10000000:1 5MS VGA DVI HDMI - Acer - ET.FS0HP.A01
Just on price alone, the fact that this ships with all of the appropriate cables and that it's currently got a $5 ground shipping deal makes it worth looking at.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Tight budget what to do? xtreme1 New Builds 7 February 28, 2011 03:11 PM
Super Budget Build SneakySnake New Builds 4 October 15, 2010 02:54 PM
Super Budget Build Iphikratous New Builds 20 April 12, 2010 04:19 PM
newb tight budget build Weak15Ten New Builds 4 August 5, 2009 11:04 AM
Tight Budget Overclocking! Digital_fx3 Overclocking, Tweaking and Benchmarking 18 April 27, 2008 03:52 PM
