Old August 5, 2012, 07:02 PM
Trial Member
Default Questions about 3D use
If i say have a 3d blu ray player and put in a 3d movie, would hypothetically i would be able to use any tv to display the images and use either polarized or active glasses to join the images? what is the role of a tv, hdtv, and 3dtv in regards to displaying 3d content?
might sound like a dumb question but im sure u guys can quickly answer for me.
Old August 5, 2012, 11:19 PM
Generally you will want to use a 3D Television or projector to display the image, these will have 120-240Hz ratings, and be marketed as 3D-ready. A 3D movie is in it's most basic form, the same movie over-lapped to provide a perception of depth, or in other words two instances of the same movie on the same screen at once, one for each eye. A 3D-ready TV has improved processing power for this to happen.
There are no dumb questions, only avoided mistakes.
I have found the active glasses to provide a much better viewing experience, but they gave me headaches after awhile.
Old August 6, 2012, 06:02 AM
KaptCrunch's Avatar
check out your moniter if 3D ready
AMD CPU Questions Masteroderus New Builds 12 April 25, 2012 05:13 PM
Questions on Using Old UPS bovine.baron Power Supplies 5 September 2, 2009 07:17 PM
:New: Questions. crazyhorsejohnny HardwareCanucks F@H Team 28 August 25, 2009 02:06 PM
Questions on my new rig. xile042 New Builds 5 December 11, 2008 10:20 AM
Few questions AnthraxAdrian CPU's and Motherboards 2 April 13, 2008 07:08 PM
