Old July 10, 2012, 07:57 AM
Default triple monitor stands
hello canuckers,
I'm thinking of getting a triple monitor stand because 3 lcds on my table take up too much space...I was wondering if any of you have purchased one of these and if you have any opinions on the following stands:
The Spacedec SD-FS-T by Atdec
or
Planar 997-6035-00 Triple Monitor Stand
sincerely
mleunm
Old July 11, 2012, 01:20 AM
Default Triple stand
I have the 3 way XFX stand NCIX sells,pretty cool but spans almost 6ft with 3 24" monitors.
Old July 11, 2012, 07:45 AM
powerbench
thanks for the info but the xfx stand is pricey wheras the ones I mentioned are a little cheaper....
mleunm
Old July 11, 2012, 10:39 AM
I been looking at a Tyke Supply monitor stand. Some have used a Monoprice one. The review link is for a dual monitor stand from Tyke but decent read regarding what to expect.
[Phoronix] Tyke Supply Dual LCD Monitor Stand Review
Old July 11, 2012, 11:05 AM
The XFX is the same as the Planar, but looks nicer and is about $70 more if you pricematch @bestdirect. The Planar is the cheapest triple one I found when I was looking into them.
Old July 11, 2012, 07:16 PM
BlueByte's Avatar
Quick question, has anyone tried wall mounting one of these triple monitor set-ups?
Old July 12, 2012, 02:21 AM
Thats allot of weight for a single wall mount.
I did 3 wall mounted 27" monitors on swing-arms that worked quite well.. but you just need to be sensible with fixing them to something solid enough to take the weight.
Old July 12, 2012, 06:09 AM
BlueByte's Avatar
I have a solid wall to tap into. just don't want to eat up space on my desk with a big mount like whats on the XFX and Planar models. I like the look and price of the Planar one, looks to be what I would go after.
Old July 12, 2012, 10:40 AM
Personally, if you can go wall mounted, it's a good way to save cash and should allow up to 27" screens.. However, moving your desk is a pain.. :D
I'm guessing but a swing arm wall mount should cost about 70 bucks (was 65 yoyo's here but we get ripped off for everything)
Be very accurate with the height and spacing of the mounts and you should be pretty good (to within a mm or so) for matching the heights..
You can also slightly adjust the height using washers or adjusting the tightness of the swing arm if your a lil off..
Managed to match the 3 monitors to within about .25 of a mm fairly easily..
did it on a stud wall, just have to find the solid bits to screw into.. (4 x 3" screws easily held a 27" screen)
[WTB] Triple LCD Display Monitor Stand dlactin2408 Buy/Sell & Trade 13 March 10, 2012 04:35 PM
Triple Monitor Setup ihaveproblems Display Units 2 August 7, 2010 05:42 PM
[WTB] Triple SLI Bridge CroSsFiRe2009 Buy/Sell & Trade 2 June 29, 2010 02:23 PM
Dual Monitor Stands RJones Display Units 1 November 17, 2008 07:59 PM
Triple SLI is here.... Prof. Dr. Silver Video Cards 16 December 19, 2007 04:55 PM
