Old July 3, 2012, 11:42 PM
GT7R's Avatar
Originally Posted by Masteroderus View Post
Apparently we can't really see above 30Hz.
Really?
15 FPS vs. 30 FPS vs. 60 FPS - Bo Allen
Old July 7, 2012, 06:29 AM
Originally Posted by bigFOIG View Post
holy sh1111t 315$ on ebay...humm it can't be the same thing i guess
Old July 7, 2012, 10:32 AM
Check out Samsungs PLS yes something different :) SA 850 24" awesome.
Old July 7, 2012, 02:06 PM
O_o
I've got Nvidia though :I
With a 120hz monitor and fps above 60, would I be able to read text better while moving/rotating in an fps game? Like text on a wall or something, I mean.
Old July 8, 2012, 04:30 PM
bigFOIG's Avatar
The ones on ebay are the same monitors basically, but will most likely not be able to do 120hz. The monitors that you order from 120hz.NET - Latest News will be guaranteed 120hz, but you pay about a 100-150 premium for it compared to the 60hz ebay monitors. Still very worth it when you put it up against similar monitors. When I mean similar monitors, I mean 2560x1440, 24" IPS. Big name monitors of this type won't do 120hz, yet they are over double the price of these.
Old July 8, 2012, 04:32 PM
bigFOIG's Avatar
Originally Posted by Flakk View Post
O_o
Not an expert on 120hz monitors but I think it would make a difference in your situation. In FPS, your game will look waaaay smoother, that's a given. So I would assume that your text on the walls would be easier to read while you're moving.
Old September 2, 2012, 07:30 PM
I have the HP ZR24w and BenQ's XL2420T. Viewing both monitors side-by-side, anyone can tell in about 2 microseconds the colour accuracy on the HP is much better. On the BenQ, the mouse scrolls much more smoothly across the screen :)
I just read the original post and skipped the end with a quick reply. I haven't posted much here, but I hope that helps a bit.
Old September 2, 2012, 08:08 PM
Get both.. :P
120HZ Monitor for gaming worth it? Ash Display Units 22 March 27, 2012 04:20 PM
High-end monitor help, PLS, IPS, 120hz? Ohmycaptain Display Units 0 December 14, 2011 08:57 PM
120hz LCD Fudd Rucker Display Units 0 March 3, 2011 08:02 PM
Response Time or 120Hz? AmuseMe Display Units 9 January 31, 2010 12:59 PM
New LCD TV : 60hz or 120hz...? Synth Display Units 10 May 4, 2009 04:47 PM
