<~----> calibrating my HDTV - Hardware Canucks
Old June 28, 2012, 06:56 PM
great_big_abyss's Avatar
Default calibrating my HDTV
I know there's software I can use to calibrate the colour and brightness settings on my HDTV. It spends most of it's time hooked up to my HTPC, so anything for my computer would work.
What software is this? There's one specifically that SKYMTL recommends...
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old June 29, 2012, 03:54 AM
JD JD is offline
This is a good starting point: Welcome to Tweak TV*-*TweakTV
They have settings for a vast amount of TVs.
Old June 29, 2012, 08:48 AM
dandelioneater's Avatar
There are calibration ''pucks'' that you can get from datacolor to calibrate your tv. I think this one will tell you which settings to physically adjust on your tv.
Looking for a New HDTV; Need Opinions SKYMTL Display Units 14 October 13, 2011 08:47 AM
HDTV Help joeperson Display Units 8 November 29, 2010 10:33 PM
Going from Laptop to HDTV Arinoth Troubleshooting 9 July 5, 2009 07:28 PM
Hdtv and new 5.1 system Jonwall Audio 6 February 28, 2009 02:28 PM
How to hook up to HDTV? LegendofJubei Display Units 15 December 7, 2007 11:02 PM
