<~----> Perfect Pixel 124hz Yamakasi Catleap Q270 - Hardware Canucks
Old June 28, 2012, 05:54 AM
Default Perfect Pixel 124hz Yamakasi Catleap Q270
So I just bought this the other day, it was the perfect pixel one in stock and I have a question about it for those who may know. I asked the seller but he told me he wasn't sure. this is the monitor right here
★★★Perfect Pixel ★★★ 120Hz Overclock ★★★ Yamakasi Catleap Q270 Multi Monitor | eBay
I was wondering if this monitor can do 3D. I just bought a GTX 680 to go with this monitor and get the 124hz out of it and I notice that on the item description it says
"Special Limited Edition - 2560x1440@120Hz (3D FPS, MMORPG) only 100 qty in the world for pilot launch."
Old June 28, 2012, 06:56 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
In a word: no.
A monitor has to be certified for NVIDIA's 3D Vision in order for it to be compatible with their stereoscopic hardware.
Old June 28, 2012, 07:47 AM
alright thank you. I wonder what 3D FPS, MMORPG means.
Old June 28, 2012, 07:48 AM
SKYMTL's Avatar
3D is possible, but no through NVIDIA's solution.
Old June 28, 2012, 07:50 AM
Oh you think so ? that's crazy if it can do 3D for a monitor that size and resolution. Time to google!
Old June 28, 2012, 08:22 AM
SKYMTL's Avatar
One possibility is AMD's solution but the effect likely won't be all that great.
Old June 28, 2012, 08:28 AM
"Quote This..."
There are hacks out there to fool nvidia into thinking your monitor is an approved model. I did it successfully with my BenQ projector. Google around a bit, it involves modifying the .inf file for your monitor.
Black belt in CAPS LOCK.
Old June 28, 2012, 08:50 AM
SKYMTL's Avatar
I'm not sure how that is possible on all monitors. The refresh rate would have to perfectly sync up or you'd get some serious flickering.
Old June 28, 2012, 02:49 PM
I rather not mess with that. I'll just enjoy the 124hz and high res with my new 680. :)
I am upgrading from a 24 inch benQ V2400W that I got almost 5 years ago so I am sure I'll be satisfied enough.
Old June 28, 2012, 03:48 PM
Phill's Avatar
Wait what? those displays can be "overclocked" again?
EDIT:
Wow, what a premium for the 120hz version!
CATLEAP-Q270-LED-2560X1440 $400 Justin Cider Display Units 232 June 8, 2013 12:40 AM
70 billion pixel panorama. gambel626 Off Topic 22 September 3, 2010 10:56 PM
Lg W2442PA Stuck red pixel cdn_Madrach Display Units 3 August 12, 2009 07:13 AM
New Cat's and Alternate Pixel center Dr_BenD_over O/S's, Drivers & General Software 6 June 18, 2009 06:07 PM
Dead Pixel Policy?? Prof. Dr. Silver Display Units 8 December 17, 2007 11:52 PM
