  #21 (permalink)
Old April 8, 2008, 12:32 PM
CMetaphor's Avatar
Quadfather
Originally Posted by enaberif View Post
Remember when it comes to surround sound.. the size of the speaker doesn't really matter as long as you have a good sub and receiver.
I Disagree totally and 100% completely. I had 2 5.1 setups before my current setup and always used small "cube" speakers for fronts or "bookshelf" speakers.... they are not worth it at all in my opinion. A 3-way tower speaker for both fronts will destroy any "cube" or "bookshelf" speaker setup in terms of audio quality, frequency response and maximum power. Hands down.
  #22 (permalink)
Old April 8, 2008, 12:35 PM
Cptn Vortex's Avatar
Yea i know. But coming from experience, I picked up a 5.1 setup from yamaha. Great reciever, but the speakers we SO terrible. I love the sound of floorstanding speakers, even in conjunction with a decent little sub. Room filling, clear sound. Even some decent little bookshelfs can sound amazing, so long as they are good quality. Definitive technologies is by far my favorite, but Energy (a local canadian brand) makes some great bookshelfs, and at good prices too.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #23 (permalink)
Old April 8, 2008, 12:41 PM
CMetaphor's Avatar
Quadfather
It Can sound good for movies and the like... but then again, for audio (Especially Music!) they don't sound that great and are Always missing low-mids (making the music sound empty with nothing but highs, high mids and a thumping sub).
  #24 (permalink)
Old April 8, 2008, 12:47 PM
Mmmmmmm I've had the pleasure of feeling this sub. I am in love. Definitive Technology Powered Subwoofers
It was built to replace a large Church Organ.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
  #25 (permalink)
Old April 8, 2008, 12:49 PM
This is what i'm using as my sub. It'll rock the house and annoy the neighbors if I want it to hahaha.
Soundstage Audio: Subwoofers
STAGE SUB10
Description: Powered Subwoofer
Amplifier Power: 150 watts
Woofer: 10"
Frequency Response: 36Hz-150Hz
Dimensions (HxWxD) cm: 40 x 32 x 36
Dimensions (HxWxD) inches: 15-3/4" x 12-3/4" x 14-3/8"
Weight: 28.6lbs (13kg)
  #26 (permalink)
Old April 8, 2008, 12:53 PM
Ou very nice!
Anyway, back on topic. Patriot, if you are listening, consider a good stereo receiver and speakers. If you dont think it will make a difference to you now, it will turn you into a audiophile soon!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
  #27 (permalink)
Old April 8, 2008, 12:56 PM
CMetaphor's Avatar
Quadfather
STAGE SUB10
Woofer: 10"
Whoa... thats EXACTLY what I'm using.... x2 tho! Front L sub and Front R sub, hehe.
  #28 (permalink)
Old April 8, 2008, 02:42 PM
Patriote's Avatar
Thanks again for the replies guys :)
Well, the receiver can't be that bad. It cost me around 450$ like 3 years ago. It was never used. Things changed and i never got around to use it.
Other than not having the new HDMI stuff, it should be good for a great surround sound with a 32" HDTV 1080p right guys? I'll just have to make sure to get a great set of 5.1 speakers.
Can any1 recommend some? Preferably from BestBuy.
Oh and thanks for the recommendations for the cables. I'll look into NCIX.com! Love the shop!
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
  #29 (permalink)
Old April 8, 2008, 02:49 PM
Best Buy Canada Web Store: Home Electronics: Home Audio & Speakers: Klipsch Quintet II MicroSystem
These will more than likely sound good for a small 5.1 setup. You will need a sub though, this would be a good match. Best Buy Canada Web Store: Home Electronics: Home Audio & Speakers: Klipsch Synergy Subwoofer (Sub-10)
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
  #30 (permalink)
Old April 8, 2008, 02:56 PM
Patriote's Avatar
Ouch! Man thats 1150$ + taxes! Are you crazy lol
Is there something a bit less pricey in a good Quality range?
- Asus P8Z68-V PRO
- Noctua NH-D14
