Old April 7, 2008, 04:33 PM
werty316's Avatar
Default Connecting PC to a HDTV.
#1) VGA-to-VGA
#2) VGA-to-Component
#3) I could also use component cables along with the tv-out adapter cable that came with my video card like the one highlighted in green in the following picture:
#4) DVI-to-HDMI
Which would produced the best video quality when connecting a PC to a HDTV?
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 7, 2008, 04:42 PM
Eldonko's Avatar
Hardware Canucks Reviewer
DVI
Old April 7, 2008, 04:48 PM
CMetaphor's Avatar
Quadfather
Originally Posted by Eldonko View Post
DVI
Second. Although VGA and Component can both also support 1080P for your HDTV, a Dvi- HDMI cable will provide better video quality since the video signal remains digital from the source all the way to the tv instead of undergoing 2 conversions (EX: VGA to HDTV= Digital (PC) to Analog (VGA out) -> VGA Cable -> PC input on HDTV: Analog (PC in) to Digital (TV processing and display) ). You can see with that example how less conversions makes more sense, hehe.
Old April 7, 2008, 05:22 PM
werty316's Avatar
Sweet, thanks for your replies guys
