Old May 12, 2012, 12:43 PM
Default Need help deciding...
Going to be purchasing a new monitor and trying to find out which will give me more "wow" factor? Currently using a BenQ V2400W 1920x1200.
Choice 1. A 1920x1080, 120hz, 3D light boost capable display using nvidia 3D vision 2.
Choice 2. Samsung 27" PLS display, 2560x1440 resolution, 60hz.
I don't know if I'd notice the 60hz vs 120hz in games like bf3. I max all settings and force supersampling, ambient occlusion etc in games like skyrim. Highest FPS I can get on my system would be around 70-80.
Old May 12, 2012, 01:21 PM
Adzsask's Avatar
HP ZR2740w has the best bang for the buck for 27 inch screens right now, not many calibration options so has to be done with software(I use software over monitor controls anyways) Also usually around $350 + cheaper then the sammy.
Old May 12, 2012, 06:40 PM
oh 2560x1600 monitors, y u so far out of my price range?!?! I really want one but i probably couldnt even fit one on my desk, i say go with the 27in monitor, more resolution = more win.
Help in deciding GPU erjohnz Video Cards 17 April 4, 2012 07:52 AM
Need help deciding on WC kit Keltron 3030 Water Cooling 23 September 21, 2011 04:02 PM
help deciding which GPU to get? bushwickbill Video Cards 6 April 10, 2011 11:42 AM
I need help deciding. encorp CPU's and Motherboards 16 March 13, 2009 12:07 AM
Deciding on a Case BALISTX Cases 6 May 19, 2007 09:55 AM
