Old March 26, 2012, 11:35 AM
Default To Dual or not to dual
I've been debating my in-home office setup and would like to get the opinions of other computer users/gamers since I am a slave to general consensus.
I have a Mac Mini with a single 24" Samsung LCD and my Windows desktop has two 22" LCDs mounted on a dual display stand. Normally any games I play on the Windows machine run on the primary display while the second stays dormant or I use it to do other tasks in between. I haven't had much luck spanning a single game across both monitors and when I have done so the screen bezels create that annoying gap in the center anyway. Mac is mainly used for iTunes & email.
I've ordered a new HD7870 and am now considering swapping displays around, 24" on desktop & and 2x22" on Mini. Would the dual monitors be overkill on the Mac? The benefit I could see is the single monitor delivers more immersion in games since peripheral vision won't pick up the blank second screen. The trade-off is the HD7870 only has a single DVI port so I would have to use a Displayport-to-DVI adaptor to run the 2nd screen. This is also true if a moved the monitors over to the Mac.
What do you think?
System Spec Peripherals: NZXT Kraken X42 CPU cooler | Zalman MFC3 fan controller | Steelseries Apex M800 kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakersDrobo FS 6.5TB Synology DS1515+ 15TB
Laptops: Asus G74SX-DH71 | Asus G752VY
Surface Pro 4 Core i7/256GB
Old March 26, 2012, 12:09 PM
More workspace is always nice, I love dual monitors. If I could have a dual screen laptop for school I would.
Old March 26, 2012, 12:11 PM
Supergrover's Avatar
Sounds like a good plan, with dual displays on the mac , as you said, you can use it for chats/ mail, monitoring ( and/or remote monitoring of the PC) ect, ect. IMO this is a slightly better setup than just dual on the PC, since clicking (alt-tab) out of a game can sometimes be a pita, with what your proposing you would simple turn and type, ect. I have used a similar setup a fewtimes before, pc= main display, secondary pc handles the other 3 displays, using synergy or mouse without borders to control and switch between machines seamlessly.
R.I.P.
Old March 27, 2012, 04:29 PM
I would do dual-monitors on your mac mini if you use it mainly for productivity. I much prefer a single monitor solution for gaming, although I guess I would do 3 for eyefinity if I could afford the desk-space.
Old March 28, 2012, 11:18 AM
Thanks for all the replies! My HD7870 showed up today so tonight I shall be swapping monitors around to try it out. Cheers!
Sapphire Announces New HD 6970 Graphics Card with Dual-BIOS and Dual-Fan Cooling Sam_Reynolds Press Releases & Tech News 1 November 1, 2011 11:50 AM
[WTB] GTX 295 Dual PCB elwoodz Buy/Sell & Trade 0 August 12, 2010 09:10 PM
Where to buy XSPC 5.25 Bay Dual Res, Dual DDC Pump Kartner Water Cooling 11 July 1, 2010 09:14 AM
xspc dual bay dual ddc pump resivour gomer Water Cooling 12 May 10, 2010 04:00 PM
Need a Dual rad HaDeS Water Cooling 10 November 3, 2009 02:46 AM
