Old March 18, 2012, 11:45 AM
CMetaphor's Avatar
Quadfather
Default Need help! Identify a 5.25 USB LCD display
Hey all, i have the below 5.25 usb lcd module that i want to toss into my HTPC (since i never use the dvd drive in there anyway). Problem is i got this a few years ago (2-3) and can't remember the manufacturer or model # - which means i cant find the programmable software i once had to control what is displayed.
Here are a few pictures:
Does anyone have any ideas what this might be? Last time i tried plugging it in i had the backlight go on but no info on the screen. Its white characters on a blue background, and i believe is 20x4.
Thanks in advance to everyone that helps.
Old March 18, 2012, 11:56 AM
KaptCrunch's Avatar
crystalfontz comes to mind but kinda looks a temp / fan moniter screen ......what happens with powering it up via floppy connector .....does screen give any info molex is the output power
would need a multi-meter to figure out the pinouts on floppy
or the floppy is the usb port and molex is power
Old March 18, 2012, 11:59 AM
KaptCrunch's Avatar
no printed data on the lower circuit board ?
20x4
try driver
Old March 18, 2012, 12:17 PM
CMetaphor's Avatar
Quadfather
Its definitely not a fan/temp controller, i seem to remember multiple programmable screens (think EQ, processor usage, etc etc etc).
When i power it up in a system the backlight turns on the first character blinks like a cursor. Windows update installs a driver "FT232R USB UART" which then becomes a Usb serial port. At that point, im left with an unknown usb device, which im assuming is the display controller itself. Can't get beyond that point
The only i found is "2004C" and "0640" on the back of the LCD PCB itself (third picture). Nothing on the first (main) PCB except for "LCB USB interface board"
That main PCB also has the following jumpers: Boot (closed), Clean (Closed) and PGM (all open, 6 pins in a 3x2 grid).
Old March 18, 2012, 02:49 PM
Mena's Avatar
I have seen that before in my Shuttle days. I am pretty sure that it is what the other guy said...a Crystalfontz. Try their software and see if it works.
I am watching you.
For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.
When a ladder was stolen from a store the manager said that further steps would be taken
Old March 18, 2012, 03:29 PM
Nodscene's Avatar
You could always try System Information For Windows. This should at least give you a vendor id or other hardware information on it.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old April 28, 2012, 11:51 AM
CMetaphor's Avatar
Quadfather
Little update: Nothing from Crystal fontz or Matrix Orbital seem to work, System info only lists the USB serial converter and USB COM3, nothing else.
Im out of ideas...
Old April 28, 2012, 12:17 PM
Dzzope's Avatar
If it's a few years old then you may have trouble finding drivers for Win7 for it, especially if it was discontinued before or around when Win 7 was released.
DVI -> DISPLAY PORT -> MINI DISPLAY PORT -> GPU ? JoshOohAh Video Cards 2 December 25, 2010 08:44 PM
auto-identify + sort pictures by file names? mike.mgs4 O/S's, Drivers & General Software 0 February 20, 2010 10:46 PM
Identify a rack! odis172 CPU's and Motherboards 3 January 1, 2010 12:10 AM
display for ps3 Jim Display Units 5 December 15, 2009 05:38 PM
