<~----> CATLEAP-Q270-LED-2560X1440 $400 - Page 23 - Hardware Canucks
  #221 (permalink)
Old October 16, 2012, 05:16 PM
mrjuggles's Avatar
Apparently Red-cap is going to be sending me a new pcb for my Shimian.
  #222 (permalink)
Old October 16, 2012, 09:47 PM
Realityshift's Avatar
Mines coming from Red-cap, hoping for the best, its in edmonton now so should see it tomorrow night...
The Builders Hammer
  #223 (permalink)
Old October 17, 2012, 08:07 PM
Monitor showed up today, so far plugged it in, worked flawlessly, and OMG the picture on this thing is amazing, I thought you guys were just talking it up but it kicks the crap out of my old samsung P2370... From what I can see there is 1 stuck pixel but unless its a black or white screen its very hard to notice. So far no back light bleed at all though =) all in all best purchase this year hands down.
The Builders Hammer
  #224 (permalink)
Old October 17, 2012, 08:19 PM
geokilla's Avatar
For those that say these monitors are awesome, is it because they're "Apple" grade? Or because they're IPS? Because I compared the screen of my sister's UX32A to my 3820TG and while the UX32A does look better, the different is not, to me, worthy of a significant investment.
  #225 (permalink)
Old October 17, 2012, 08:56 PM
For me I think its a little bit to do with the higher contrast ratio, brighter LED back lighting and better colors then my old monitor, but the smoothness of the higher resolution also plays a big part of it, like switching from the old apple 3g to the retina display, text is sharper ect.
The Builders Hammer
  #226 (permalink)
Old October 18, 2012, 12:22 AM
For me the size, resolution and image quality was appealing. When compared to direct competitors in the 27 inch market it was the clear winner.
27in TN panels at 1080p for cheap are garbage.
27in VA panels at 1080p are equally priced and lower resolution.
Dell, HP and Apple's $1000 monitors are way too costly.
a 27in 2560x1440 S-IPS for $325-400 is simply the most appealing deal out there and I'm extremely happy with mine.
I would say it's awesome because it's an "apple" grade display in a cheapish plastic bezel. Which I don't really give a hoot about the stand and frame being plastic and relatively cheap feeling when the display itself is everything I could ask for.
  #227 (permalink)
Old October 20, 2012, 02:30 PM
Ok so after a few days of use, I can confirm I have a single stuck pixel, seems like its a redish color but I honestly dont notice it. Other then that the stand works fine, it supports the weight without any issues and the tilt feature seems to work. Over all im pretty happy with it, red-cap got it to me in 2 days which is pretty amazing, and gaming wise its a joy to play on. Highly recommend to anyone thinking about going with a Korean screen.
The Builders Hammer
  #228 (permalink)
Old October 21, 2012, 02:35 AM
Yours didn't work right. I have taken apart 2 LCDs it can be a bit tricky to connect the wires and closing after, good luck.
I have a samsung 23" with its internals working fine, but I broke the screen. I should list its internals on ebay since I ripped it apart after it sat there for 2 years
i5 2500k - 7950 3GB crossfire - 4GB 1866 CL9 - 1080p
  #229 (permalink)
Old October 26, 2012, 11:25 PM
mrjuggles's Avatar
I received the new pcb from red-cap today.
pcb02 by mrtophat1982, on Flickr
pcb01 by mrtophat1982, on Flickr
Anyone know if sam young caps are any good? I might change them just to be safe before installing it.
Hopefully it will go smoothly, I recapped a samsung lcd about a year ago and know all about the trickiness involved in getting these things taken apart.
  #230 (permalink)
Old October 29, 2012, 07:29 PM
never heard of them, does the apple operation make the PCBs ?
