  #141 (permalink)
Old September 17, 2012, 05:14 PM
Alpine's Avatar
crap mine dosen't fit in on my computer desk for the moment. It is just a little bit to high
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
  #142 (permalink)
Old September 18, 2012, 06:03 AM
mattlef's Avatar
LOL Alpine, that sucks.
which pannel did you get again? Maybe take off the stand and rig it up against something with VHS tapes? its what i did before i had it mounted lol. I knew saving those old pos tapes would come in handy some day.
CC-HotSpot Host
YouTube Instagram Twitter
  #143 (permalink)
Old September 18, 2012, 06:18 AM
Alpine's Avatar
this one:
http://www.ebay.ca/itm/330723707326?...84.m1497.l2649
The monitor it is .25 of inches to high to fit in. I have solve the problem by removing a part of it.
I really need to buy a mount wall, then i will be able to use my computer desk completly.
Main system
  #144 (permalink)
Old September 18, 2012, 06:27 AM
mattlef's Avatar
or you can look at getting a decent desk mount.
These only weigh about 15-20lbs, so you might be able to find a decent mount for around $60-100bucks.
CC-HotSpot Host
  #145 (permalink)
Old September 18, 2012, 06:57 AM
Alpine's Avatar
a desk mount.....nice idea !!!
Main system
  #146 (permalink)
Old September 18, 2012, 03:13 PM
Musabi's Avatar
How would a GTX 480 hold up with one of these? I play at 2048x1152 now (yes, 16:9, I know, weird haha) and everything runs great at high settings. Wondering if I'll need to buy a 670 for this... heh.
  #147 (permalink)
Old September 18, 2012, 03:58 PM
mattlef's Avatar
It would basically perform the same as my 570.
Its okay... but gets the crap kicked out of it in some games. So far BF3 plays decently, but that's all I have tested so far. I'd upgrade personally. i'm working on an upgrade as well.
CC-HotSpot Host
  #148 (permalink)
Old September 18, 2012, 04:13 PM
maverick_brent's Avatar
For the best expirence I would upgrade , but either way just the monitor used for the extra real estate is worth it....
  #149 (permalink)
Old September 19, 2012, 05:40 AM
But how does 6ms refresh time compare to 2ms in games?
But for the eye candy of 2560x1440, I think I'll definitely start saving and get one for christmas
Oh and I hear taLK OF THEM Having tempered glass, does anyone know of ones with matte finish like most normal LCDs?
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
  #150 (permalink)
Old September 19, 2012, 05:51 AM
Alpine's Avatar
mine is dead:
MVI 18091 - YouTube
Main system
