Originally Posted by Gonzo The flickering at startup is the key. The Capacitors need replacing. The top of the cans will be domed, so it's easy to tell which ones need replacing. When ordering new ones, you should replace them with ones of a slightly higher voltage. This way they will never need replacing again.
Digikey is good place to order them look for Panasonic ones. total cost will be about $5.00. |
The thing is that it's not flickering at all it's just hissing loudly. There are no problems I can tell other than the hissing. No smell of burn electronics no fade of the screen. I guess it's giving me advance notice it's time to get a matching set of monitors. This one is about 4 and a half years old and it was a display model at futureshop so I got it super cheap while my Philips monitor is only a year old. So I guess I should really be asking now what monitor should I get?
My requirements are it must have at least 3 inputs preferably VGA, DVI, HDMI(or DVI) must be 1080p and must be approx 24" I don't want smaller and my current desk can't hold much larger but I'm open to suggestions.
Here's a monitor I was looking at earlier.
ASUS VE247H 23.6IN Widescreen LED LCD Monitor 1920X1080 2MS 10M1DC HDMI DVI-D VGA Speakers - ASUS - VE247H
