Old February 5, 2012, 04:19 PM
Default Physical display size and video memory
I have a few questions about available video memory and how having a larger display affects it. I am running an EVGA Classified GTX 590 out to a 52" 60Hz Sharp Aquos TV for a main display. Will the size of the TV adversely effect the way my games perform? If so, would I be better off getting a smaller monitor capable of higher refresh rates? Or just upgrading my video card solution to a 4 way SLI config?
Thanks!
Old February 5, 2012, 04:25 PM
Supergrover's Avatar
Your res is 1920x1080, it isnt about the size of the screen but about resolution size, res size determines the pixel destiny, more pixels more horsepower is needed.
If you want a visual upgrade then grab a 30" dell or Sammy with 2560x1600 or a 27 with 2560x1440 it will look soo much better than gaming on a 1080 TV.
R.I.P.
Old February 5, 2012, 04:34 PM
supaflyx3's Avatar
Pretty much what grover said, a 22" 1080P monitor would perform just as well as a 52" TV would, but it would look worlds better on a computer monitor.
Old February 5, 2012, 04:40 PM
So the only performance related limitations come from multiple displays (EYEfinity, Nvidia Surround) Right?
Old February 5, 2012, 04:42 PM
supaflyx3's Avatar
Or higher resolution monitors, yes.
Old February 5, 2012, 04:50 PM
With that 590 you have enough horsepower to power a single larger monitor gaming, I wouldnt try it with a 3xu2711 say.
The 590 @ a res of 1080 is overkill but would work very well at 2560x1440/1600.
The jump in density is pretty big once you move from 1080.
Edit:
Here is a quick example incase you dont understand me, disregard if you do:
1920x1080=2073600 pixels
2560x1440=3686400 pixels
2560x1600=4096000 pixels
So you can see the difference from a 1080 to 2560x1600 is almost dbl.
R.I.P.
Prob with display/size monitor camrun1us Display Units 0 October 3, 2011 08:29 PM
setting physical size in multo monitor setups bissa Display Units 7 July 19, 2011 03:16 PM
video card size question esanity Cases 3 February 17, 2009 12:06 AM
Video Card memory 512 Available video memory 1268 mb? TwystedMonkey Troubleshooting 4 August 24, 2008 06:07 PM
Physical video card mods (not cooling mods) chibi_man Video Cards 6 January 29, 2008 09:32 AM
